Opening a recently used session from the Dashboard causes PT 12.5 to crash
Possible bug found this morning on Pro Tools 12.5. When booting PT today I tried to load a recent mix session from the start up splash screen. Pro Tools crashed immediately... I have replicated the same crash several times. It does not happen, however, if you open the same session via the open from disk menu or indeed if you open a recent session from within pro tools.
Has anyone else noticed this behavior?
Mac Pro 2x2.8 ghz Intel Zeon, 20 gig ram, Yosemite 10.10.5, Pro Tools 10,11,12.7.1, Logic Pro X 10.2, UA Apollo 16 quad, UA Octo Pcies, Dangerous Music 2 Bus, Antelope Audio Satori, Lynx Studio Hilo, Neve 542, Neve 511, API 505 DI, Bettermaker CV502. Avid Artist Mix, Avid Artist Control, Softube Console 1 mk11. |
Re: Opening a recently used session from splash screen causes PT 12.5 to crash!
I can confirm this. It happens with me too. I need to open from disk and not from the splash screen or it crashes.
If you hold down the SHIFT key while opening the session, does it still crash?
http://www.pro-tools-expert.com/home...e-all-plug-ins
System Specs: http://duc.avid.com/member.php?u=108915 Audio Reel: http://www.wacc.net/ https://soundcloud.com/13guatamas13 |
Yep still crashes,makes no difference so it's definitely not a plugin issue. Any other ideas? It never happened in 12.4 ... Thanks
Yep done all the usual stuff before posting it as a potential bug ... Just a thought, I don't have my work Mac Pro connected to the Internet, I'm going to connect it now to see if that may be the cause
Ok, I can confirm that it works fine if connected to the net... That would appear to be the solution... Question is, how would you stop that so that it behaves normally without the net connection as being connected interferes with my artist control and mix units
PT125_openRecent.jpg I am not seeing this behavior on my system (Windows). Both SESSIONS and PROJECTS open fine from the Dashboard. I would try trashing prefs as suggested.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Already done the prefs ... It's not that , please see my revised post above
I unhooked my computer from the internet to test this and I am now getting an error when trying to open a SESSION from Recent in the dashboard. No crash, just an error. PT125 RECENT_noInternet.jpg Oddly enough, I am able to open PROJECTS from the Dashboard > Recent with no problems. I guess technically Projects shouldn't even be showing since I'm not connected to the net. Also, as others have said, I am able to open a SESSION from FILE > Open Session or FILE > OPEN RECENT. And as soon as I connect to the internet, Dashboard > Recent works as it should. Looks to be a bug.
Weird PT 11 Crash while opening a session | L-Mart | Pro Tools 11 | 2 | 05-09-2015 11:02 AM |
PT 11 Crash Upon Opening Session | SoundtrackArcade | Pro Tools 11 | 5 | 01-14-2015 01:00 PM |
strange crash on opening session | sound_music | Pro Tools TDM Systems (Mac) | 5 | 02-27-2012 07:51 PM |
PT 9 crash while opening PT 7.4 session | jesseblu | Windows | 3 | 09-27-2011 06:57 PM |
