Analog out card for a 192 Digital interface?
Hey there, I was wondering if it is possible to add an analog out expansion card into a 192 Digital interface.
Seems like it should work, just need to see if this is possible before buying a DA card. |
Re: Analog out card for a 192 Digital interface?
As long as there is not already an added input card, yes..
You can have either an additional 8 in or 8 out but not both. |
Thank you very much!
Just in case I miss spoke are you talking about the I/O that is just digital with no analog inputs or outputs now?
If so then I don't think so.. |
That's exactly what I'm asking... the 192 Digital, not the standard 192 i/o.
192D can not support an analog card, it dose not have the power rails for the analog circuitry
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Allrightythen. Thanks for clarifying!
I don't how accurate this power supply rails issue is ?
if you've ever actuall opened a 192 digital it's identical to a standard 192 it has all the cables for all 4 bays identical to 192 analog, same PS # so unless avid is actual manually disabling rails ( which seems really unlikely ) as a cost saving feature then why leave all 4 ribbon cables for all 4 bays? I know for a fact that it is the firmware that differentiates a 192 d from a analog unit is solely the firmware the confussion I think is that the firmware is in the power supply assembly so that is where this rails issue is mistakenly drawn from so adding anything into any slots #1-2 other than the dig IO cards are disabled and adding anything into slots 3-4 no matter what are disabled regardless what card it is
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
Maybe some digital units were built with the analog supplies, maybe, I have no idea, but I know what MY units have in them. No analog IO, no way. |
the draw rating is 1.5A for the 192D and 2A for the 192 I have opened plenty up just not both a 192 and 192D at the same time and compared PSUs the 2 extra ribbons probably costs an extra 30 cents, it's probably more expensive to do a separate run to leave them out load the different firmware, and a PSU that doesn't have 12 or 15 volt rails and there's the costing less. I'll willing to admit that maybe Avid did not put a different PSU in
Can I put a 192 A/D card into a 192 Digital interface ? | Lizardpoint | Pro Tools TDM Systems (Mac) | 3 | 04-12-2010 02:22 PM |
Analog card for 192 digital? | IO Composer | General Discussion | 2 | 08-17-2005 07:04 PM |
Okay we got the all digital interface - what about an all analog interface? | uno1234 | Pro Tools TDM Systems (Mac) | 2 | 04-24-2002 12:50 AM |
SDII/Digital Interface/Analog Interface Question | Karmitz | Digidesign Hardware & Software | 1 | 07-15-2000 12:30 AM |
Sound Tools digital/analog interface question | Karmitz | General Discussion | 0 | 07-14-2000 11:21 AM |
