Pro Tools has problem syncing with VS-1880
I have transfered audio via the digital ports from my VS-1880 to my 002 many times. But right now I am having problems with it. I have the VS-1880 set as the master and the 002 sees a MIDI signal but Pro Tools will just sit there waiting to sync up. This is the second time that this has happened. I have gone over the settings and the connections numerous times and everything seems to be in working order. I have also tested the MIDI cables on other sources and the are working fine as well. And for both occasions when it did not sync up I just used it a few hours before and it was working just fine. Anyone else experience something like this? Is there some small detail I somehow have omitted? Thanks for any help you may provide.
Re: Pro Tools has problem syncing with VS-1880
goto windows/sessionsetup and set the starting time. By default ptle will start a session at 1:00:00:00 (one hour).
What's that? - That's the machine that goes "pling". Bastiaan |
I have the startup time to start at the 3 second mark. But that leads me to remember that I failed to mention that Pro Tools doesn't even see the incoming time found under the session setup. But the 002 still shows it is taking in a MIDI signal.
So I thought I would go ahead and mess with this again in spite of Digidesign offering a solution and now it works again. Now I wonder if I need to start things up in a certain order. Or is this caused by something else?
Pro tools and logic Syncing Problem | ralfddd | Pro Tools TDM Systems (Mac) | 0 | 10-12-2006 04:08 PM |
Syncing Pro Tools and Roland VS-1880 via MIDI | mudman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 12-22-2005 02:08 PM |
Syncing the Roland VS-1880 to Pro Tools digi002 | guitar gar | MIDI | 1 | 06-28-2005 10:15 AM |
Roland 1880 and 002 Rack syncing (revisited) | Ruzzo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-29-2005 03:50 PM |
Syncing 002 with a VS-1880 | seths | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-19-2004 07:22 PM |
