Old 08-08-2017, 06:21 AM
bradch00 bradch00 is offline
Default Re: Superior Drummer taking up cpu 40%! even cached! Am I doing something wrong?
Originally Posted by Marsdy View Post
What buffer setting in Pro Tools?
Are you streaming the samples from your system disk? Not a good idea. With most of these sample streaming engines, the faster the disk the lower the load on the CPU and the system disk is busy doing other stuff.
In normal operation Superior2 loads it's samples into RAM when the kit initializes. Cached operation requires the samples to be loaded one time as each articulation is triggered (i.e. as each kit piece is hit) this does take system resources.
Pro Tools, Studio One Pro
2022 Mac Studio M1 Max 64GB-1TB NVME
OWC Thunderbay Mini (4TB SSD)
OWC Express 4M2 (4 X 2TB)
Interface: Presonus Quantum
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig)
Old 08-08-2017, 05:45 PM
willl3 willl3 is offline
took some advice -
created new project one track
using superior drummer 2
using default 2 tracks (not multi)
got me down to 4 to 5 one the system use CPU
so using multitrack out from superior is the issue it just sucks a ton of cpu
I like to have control of all my drum tracks so the only way is to record them to save cpu.
any one else have this issue
windows7 HP XW8400 Workstation Xeon Dual-Core 5150 2.66GHz 12gig ram
Old 08-08-2017, 11:53 PM
Try moving the kit pieces or groups (rack toms, floor toms) to separate channels in SD2 with aux tracks in PT, one by one and see when the CPU starts going up.
I always mult-channel in PT with SD2, but I am also on Mac, not Windows 10. Someone else on Windows 10 may be able chime in.
Old 08-09-2017, 03:23 AM
right now if I do multitrack out and aux track in PT a get that super high cpu reading.
I will try your advice today do them one by one
also multi track within it self has like three tracks for bass drum and two for snare so that set up I have to assume eats up cpu power.
I thought with so much ram (I've been using protools since ver 6)
plug in take up so much cpu was a thing of the past... nope!
thank for everyone help here.
Old 08-09-2017, 05:49 AM
This is how I usually work, (and what groups I make depends on what kit and SDX are in use and what kind of sound I'm trying to get but...)
I create busses in the SD mixer for example;
Kick, snare, hihat,RackTom,FloorTom,Oh,Amb..... any other things you want to group. Route all the kick mics to "kick", all the snare mics to "snare"... etc. Assign those busses to output channels in SD, then only create 6 aux tracks in PT.
Alternatively, in SD, you can assign all 3 kick drum mics to output 1/2, 2 or 3 snare drum mics to out 3/4, hihat 5/6, RTs 7/8.... etc. and only create as many aux channels as you need in PT to satisfy those kit piece 'groups' routed to outputs.
Hope I am making sense... and helping
BTW at the top of the forum you will see an option "User CP", select it, go down to "Edit Signature" and update it to the actual type of PC and processor you running. That should help in future posts.
HTML code is On
Toontrack - EZ Drummer & Superior Drummer - UPDATES Seafoam_Green Virtual Instruments 4 06-27-2016 07:07 AM
Toontrack EZ Drummer 2 & Superior Drummer Update justus1900 AAX Plug-ins 4 06-18-2014 10:14 PM
Superior Drummer taking FOREVER jmitchell1532 The Drum Room 8 12-04-2012 06:02 PM
EZ Drummer and Superior Drummer Problems verticleman Virtual Instruments 5 01-02-2011 11:41 AM
Superior Drummer and EZ Drummer on sale nst7 Virtual Instruments 0 09-01-2010 09:57 AM
