Audio Ease 360 Pan Suite v.2.0.2 Released
Now with 360 convolution reverb and added integration features.
Free Update https://www.audioease.com/360/
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W |
Re: Audio Ease 360 Pan Suite v.2.0.2 Released
I'm curious about the "position blur" setting. The site lists:
"Pan stereo music hard left and hard right and open up position blur halfway to create a head-locked effect in an ambisonics mix, That does not require separate head-locked tracks." I'd like to know if any phasing occurs from this process |
Audio Ease 360 Pan Suite Bounce
Hi! I think that the 360 Pan is a great plugin, the 360 radar is awesome, but i´m having trouble with the bounce. In a tutorial video from audio ease they say that you have to replace the 360 monitor plugin with the 360 bounce export, then change the output of the track to the 9channel bus (the input and output are the same in this track).
The guy in the video makes the bounce and sets the Bounce Source to the 9channel bus, but with the format in multiple mono, i asume that it should be Interleaved because the 360FB Encoder only receieves Quad, 8channel and 2nd order ambisonic audios wich is the one that the 360 pan delivers and they stated that the FB360 encoder is compatible. The bounce file generated (in multiple mono and interleaved) is just some kind of noise, similar to a Delay with infinite feedback. Is this normal? Am i making the bounce wrong? Should i Mix using the 360 pan but instead of using the 360 Radar use the ones from FB360? I hope you can help me, Thank you!!! P.S. I also tried to make a bounce with an example session that the guys in Audio Ease provide to see if somehow i messed up in my routing but i had the same results. |
I think the video displays incorrect information actually. The export should be interleaved, not multi-mono. Also, by setting the input and output of the track to the same bus you effectively create a chaotic signal loop.
Try creating a separate bus (7.0.2) and set your 360 Monitor output to this new bus. Then in the bounce dialog box set the output to this same bus. |
Alternatives to Audio Ease Snapper? | Marsdy | General Discussion | 9 | 08-31-2016 01:00 PM |
WTB: Audio Ease Speakerphone 2 | bits | Buy & Sell | 0 | 07-28-2016 02:40 AM |
New Audio Ease Post Reverb | MIKEROPHONICS | Post - Surround - Video | 16 | 07-03-2016 01:22 PM |
WTB: audio ease Altiverb 7 XL | dicky.chan | Buy & Sell | 0 | 05-14-2013 05:08 AM |
Audio Ease Reverb plug | kayakjack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-16-2004 07:45 AM |
