Old 08-07-2017, 10:21 AM
DJ Hellfire DJ Hellfire is offline
Default Is there a workaround for using iZotope Stutter Edit with delay compensation?
Is there a workaround for using midi-based effects plugins like Stutter Edit with delay compensation? When using Stutter Edit in a session that has massive amounts of plugin delay compensation, the triggering of the plugin is delayed a lot and off beat. Some notes you can get away with, but there are certain effects that absolutely must be on time and this plugin does not get compensated.
So the workaround I've been using sometimes is freezing all the tracks that are causing plugin delay, but then you lose the ability to edit those clips.
Another workaround is to freeze all the delayed tracks, render the stutter edit, then unfreeze. But when you are applying the stutter edit to the entire beat, you and up having to commit your whole beat mix and then some how undo all of that if you need to tweak a drum or instrument, then redo the stutter edit.
So does anyone have any methods of using Stutter Edit on beat in a mix with other plugins that cause a lot of delay (UAD)?
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
Old 08-07-2017, 11:13 AM
amagras amagras is offline
Default Re: Is there a workaround for using iZotope Stutter Edit with delay compensation?
Have you tried manually inputting a negative value on the +/- delay offset box? https://youtu.be/rkIFnUxOAAM
amagrasmusic.com
Old 08-07-2017, 02:02 PM
The problem with that in my case is the by doing this, it would delay the entire beat all of the time, which I don't want. The problem is that plugin is manipulating the audio in reference to the grid, but since there is heavy delay compensation from other plugins, the audio isn't actually playing back in exact timing with the grid. So the plugin is thrown off. Maybe nudging all of the audio would help.
Pro Tools 2021.12
Old 08-07-2017, 03:28 PM
But, what if you Ctrl-click to bypass dly, then move +/- ?
amagrasmusic.com
HTML code is On
FS: iZotope Stutter Edit Steamy Williams Buy & Sell 2 08-16-2017 05:03 AM
WTB: Izotope Stutter Edit TrentWilliams Buy & Sell 1 09-12-2014 07:03 AM
FS Izotope Stutter Edit Tops3b Buy & Sell 0 04-18-2014 11:49 AM
Izotope Stutter Edit renips1 Virtual Instruments 6 06-07-2012 09:25 PM
