  #181
Old 08-09-2019, 01:30 PM
K Roche's Avatar
K Roche K Roche is offline
Default Re: NVMe upgrade for Mac Pro 4.1/5.1 Mojave
Originally Posted by ghostwriter View Post
Yes, the directions are non-existant, but I did figure it out and was going to post photos after I got it up and running. Mine are parallel to the Crest. It turns out I did have a bad card. The new one is in and working beautifully. First thing I did was move a large file from one 970 on the Crest to the other 970. Bam, done. No crashes, PT working great.
Very cool
For World Studios info in my Crest box there was a little baggie with 8 or 10 tiny wide top screws the two dual diameter spacer nuts and a tiny little phillips screwdriver.
Also There is more fan noise probably because of the two new fans. One in the new video card and now the one in the Crest
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
  #182
Ghost In The Attic's Avatar
Ghost In The Attic Ghost In The Attic is offline
Here are a few more pics.
The first is the back of the Crest. If you look at the far left you will see the two srews that attach to the brass risers from the bottom to keep them on the board. Then another screw holds the ssd card down to the same brass riser on the opposite side of the board.
To remove the heat sink cover you will need to remove the four perimeter screws. The screwdriver they provide is a joke if they come tightened as tight as mine were. The second Crest was not near as tight. The second photo shows their screwdriver next to a jeweler's screwdriver, it's tiny.
The third pic is of both ssd drives attached.
Retro 176 (pair), Pultec EQP-1A (pair), Germanium Comps (pair), BAE 10DC (pair), Distressor (pair), Manley Vari-Mu, Sta-Level, Zener, SSL Fusion, SSL FX G384, API 2500, LA2A, 1176, Bricasti, Massive Passive, Anamod ATS-1, Eventide H3500, TC 2290, Yamaha D5000, PCM92, PCM70... Amps, Amps & More Amps.
  #183
Old 08-09-2019, 07:26 PM
Originally Posted by JFreak View Post
I wouldn't worry about it. In my 2013 trashcan Apple for some reason used heatsinked ssd's but any other brand I've used have omitted the heatsink and performed flawlessly.
I have no idea what kind of 24/7/365 100% stress test Apple has performed when they have found so much heat generated from ssd that they think heatsink is needed. After my hardest and longest stress test I can think of, opening the case and touching the ssd it is only lukewarm. I think memory runs hotter.
*No*
I would worry about it. Especially since it is almost no effort. What a Mac Trashcan has inside it, with a very carefully designed airflow to cool its SSD has *nothing* to do with the situation here in a shrouded airflow system where the manufacture has included bonding to a heatsink.
These 970 Evo will consume 6W or so under load, that might be in the ballpark of many DIMMs, but so what that's irrelevant too. Computers are designed with very specific cooling to handle that constant DIMM heat load. A small fan in a shroud in a PCIE slot with 2 x 6W, that may add up. And you are defeating that shroud as a heatshink design, not a good idea at all. These things are pretty easy to thermal model today, lots of consultants out there that will do that for even small manufacturers, so follow the manufacturers advice.
  #184
Old 08-09-2019, 11:09 PM
JFreak's Avatar
JFreak JFreak is offline
We can agree to disagree.
But the fact is; if after stressing your system you open the case and touch the components by hand, everything is okay if you dont burn your fingers.
Janne
  #185
Old 08-10-2019, 12:48 AM
But the fact is you cannot feel the temps of the M.2 drives involved, they are hidden behind a shroud...and they sure hit issues before being too hot to touch, including performance throttling and decreased life. if folks want to mess around looking at measured drive temps vs throttling specs knock yourselves out.
Everybody else can just follow the install instructions.
  #186
Old 08-10-2019, 03:46 AM
Originally Posted by Darryl Ramm View Post
*No*
I don't understand your statement of "And you are defeating that shroud as a heatshink design, not a good idea at all." - please explain. And what is this 'small fan in a shroud in a pcie slot' you speak of?
And I believe the Mac cheesegrater's cooling is actually designed for way more cooling than you think. How about putting cards in every slot in the card cage? Surely that raises the heat load?
Jack
QAPLA!
  #187
Old 08-10-2019, 06:01 AM
K Roche's Avatar
I believe the small fan he is talking about is the one mounted on the Crest Card itself (see ghostwriters post #178, the picture on right shows the fan)
I now have all 4 PCIe slots filled and I would guess the answer is yes, there is more heat generated, because as I mentioned there now seems to be more (slightly louder) and constant fan noise coming from my machine. Such that because I am in a one room situation. I will now have to address that noise while trying to record more so than before (It's always somthin' )
System :
Enjoy the Journey
.... Kev...
  #188
Old 08-10-2019, 11:05 AM
One of the questions is is the extra heat being generated beyond what the Mac's cooling system can handle? I understand there's extra heat but is it all that much to be worried about? I get the fans may be running a bit faster but again - are things within what's considered normal operating specs? I'd say get iStat Pro (I think it's a pay-for now) and see what it's saying for your internal temps.
The extra noise you're hearing - is it at the pitch the fans are running at or is it more of a rumble aka case resonance? A long time ago in another universe I worked for a company that made cooling equipment (fans, air conditioners, etc.) for electronics and racks. Sometimes a customer would say there's a problem with an assembly (noisy) and we'd get it in and power it up and everything was okay. Turns out in a lot of cases it was resonance within the rack and the way the cooling assembly was mounted. Try this if you can: if your cheesegrater is sitting on a hard surface place it on some kind of isolation material like you would put under a monitor speaker and see if the sound diminishes.
Jack
QAPLA!
  #189
Old 08-10-2019, 04:51 PM
K Roche's Avatar
I guess I am confused as to what is inspiring the question. Whatever the heat increase is, doesn't matter does it ? Given the Crest card comes with the fan already installed it seems like a non issue and thus is not a worry
The extra noise you're hearing - is it at the pitch the fans are running at or is it more of a rumble aka case resonance? A long time ago in another universe I worked for a company that made cooling equipment (fans, air conditioners, etc.) for electronics and racks. Sometimes a customer would say there's a problem with an assembly (noisy) and we'd get it in and power it up and everything was okay. Turns out in a lot of cases it was resonance within the rack and the way the cooling assembly was mounted. Try this if you can: if your cheesegrater is sitting on a hard surface place it on some kind of isolation material like you would put under a monitor speaker and see if the sound diminishes.[
I am pretty sure it is the pitch of the fans, the computer is sitting on a heavy industrial grade carpet and pad, so is somewhat iso from the floor
System :
Enjoy the Journey
.... Kev...
  #190
Old 08-10-2019, 06:02 PM
I don't think the heat load IS a worry to tell the truth.
So yeah - your machine is pretty well isolated from whatever hard surface is underneath it. Do you have some kind of system monitor s/w like iStat Pro to tell what the temps are and what the fans are doing?
Jack
QAPLA!
Mac Pro 2012 -should upgrade to Mojave? Zak7 macOS 5 06-04-2019 07:51 AM
Mojave? hanksinclair Artist Series 3 05-03-2019 03:19 PM
New 8th Gen i7 with NVMe m.2 SSD spock999 Pro Tools 2018 26 02-22-2018 11:47 PM
Bootable Thunderbolt case for NVMe drives (Samsung 950 etc) propower General Discussion 1 10-27-2016 04:11 PM
Intel SSD NVME/PCIe Porn Darryl Ramm General Discussion 0 04-03-2015 02:02 PM
