Was wondering how to resolve the clock issue when connecting the 192 digital out via TDIF into DA88 with a proper digi connect cable. I have tried blocking the Word clock in on the DA 88, as well as Ext clock out of the 192 via BNC to word in on the DA 88. Is there a way to get the Tdif specific menu box in Hardware setup that used to be in PT5.3. to be in PT6.1.
thanks |
Hello,
The option to choose "Word Clock (TDIF)" is still available in Pro Tools 6. You can choose “word clock (tdif)” in the external clock output menu in the Hardware Setup’s Main tab. Folow the directions in Abase 7981 when transferring from Pro Tools to DA88s via TDIF. http://answerbase.digidesign.com/detail.cfm?DID=7981 You will neeed to use a T-connecter on the DA88 and place the terminator on one end and connect the wordclock output of the 192 to the other. This is outlined in the abase above. Hope this helps. Mike |
DA88 TDIF Out to 192 TDIF IN | Mixing Madness | Pro Tools TDM Systems (Mac) | 2 | 11-07-2011 10:31 PM |
TDIF/DA88 digitizing problems | Katherine | Pro Tools TDM Systems (Mac) | 2 | 09-06-2005 03:24 PM |
192 I/O TDIF Connection to DA88 | Matthew Harrold | Pro Tools TDM Systems (Mac) | 1 | 08-24-2005 07:18 AM |
DA88 and 192 I/O TDIF issue SOLVED by Patrick | john1192 | Post - Surround - Video | 7 | 04-19-2005 01:28 PM |
PT and TDIF | Kevin lucero | Pro Tools TDM Systems (Mac) | 1 | 09-27-2002 07:14 AM |
