Old 07-11-2017, 07:19 PM
DannyB_KY's Avatar
DannyB_KY DannyB_KY is offline
Default How do I assign L/R inputs from generic USB2 interface? New Issues.
How would you assign L/R inputs from a generic USB device that Pro Tools doesn't automatically recognize? I have no idea where to start!
An understand spouse, some mics, tube guitar amps, gray foam stuff stuck to the walls, a drum kit, a Mac or two, and an interface. A really understanding spouse!
Old 07-11-2017, 07:46 PM
Southsidemusic's Avatar
Default Re: How do I assign L/R inputs from generic USB2 interface?
Go into settings and i/o and choose default on all tabs there. In out aux and on input and output tabs and that should work automatically.
If it doesn't then try config in there for your interface.
Make sure the interface is selected under playback engine same place (settings) and if you wanna be 100 % sure start PT with the N key held down and choose your interface when popup window appears.
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 07-11-2017, 08:38 PM
DannyB_KY's Avatar
Thank you!!!!! I got it working.
"if you wanna be 100 % sure start PT with the N key held down and choose your interface when popup window appears. "
That is a fine piece of information! Thank you again!
Old 07-12-2017, 03:38 AM
Glad it helped
Best Regards
Christopher
WEBHOME
Old 07-12-2017, 04:47 PM
DannyB_KY's Avatar
Ok. I was a bit premature when I said it was working.
PT recognizes the interface as I/O Aggregate as well as Soundflower 2ch. I can select the inputs, arm the track and..............nothing.........when playing the guitar thru it.
I'm glad the Focusrite is not like this!!
I've uninstalled PT 12.8 and re-installed 12.8.
Its killer when I run it thru the Focusrite, but that's less than half of its uses/capabilities. I have to get this, and I'm clueless what to do next.
Old 07-12-2017, 09:37 PM
What interface is it you call generic? Does it have drivers to install?
Best Regards
Christopher
WEBHOME
Old 07-13-2017, 08:33 AM
DannyB_KY's Avatar
Its Laney IRT Pulse. It has a pair of 12AX7s, approx 300V on the plates. In USB mode it records two tracks. Left side is unaffected guitar. The right side is the guitar thru the Pulse pre-amp. From country clean to full on metal. Its all I need, I think, before you hit the "Hot" button. I love this thing. But its a pain in the butt to get connected.
USB: 44.1khz Standard Slave CODEC ?????
Heres a Youtube vid with Paul Glover. He's running it in Logic.
https://www.youtube.com/watch?v=6IQkJkkjYtU&t=555s
Old 07-14-2017, 01:50 AM
panamajack's Avatar
panamajack panamajack is offline
Originally Posted by DannyB_KY View Post
. . . PT recognizes the interface as I/O Aggregate as well as Soundflower 2ch. . .
Have you used the Audio-MIDI utility to create an aggregate device? You can find instructions on setting up aggregate devices on the Apple support web page.
You would use one USB device for your input and another (your Pro Tools interface) for your output. The Laney IRT Pulse manual has no instructions on how to do that.
PT10.3.10HD(Tyan s2932 [8core Shanghai 2.7GHZ] 32GB,Win7 SP1); PT10HD(Tyan s2892 w/10GB, Win7 SP1);PT8HD(Dell 690 quad Xeon 3.0, 8GB, Win7,192 I/O, 96 I/O);MacBook Pro: 11R, Apogee Element 46, Focusrite 8PreX PT HD 11.3.2; Mac Pro 3.47 Hex 32GB, OSX 10.12.6/L10.4.2;L9.1.8, 2.64TB; G5 D2.3 4GB, 10.4.11/L8; 12c MP 2.66/32GB PT12.4; Structure, GigaGS3, Kontakt 5, Garratin, Sibelius 8.7+, Finale26,EMU,Vegas Pro 16-10/; RME HDSP9652,MOTU 2408 MKIII/1224/308, FX,Kurz,L5s,Strat,ASAT,JB,Zon
Old 07-14-2017, 09:56 AM
DannyB_KY's Avatar
Spot on!! Its not hard at all, once you know what you have to do.
Thank you!
I used USB CODEC 2 inputs, as the input and the Focusrite as the output.
"Avid Pro Audio Community : Membership has its privileges."
Sorry. I couldn't help myself.
How do I assign MIDI inputs onto instrument tracks? grateful macOS 4 03-21-2013 02:24 PM
Pro Tools 8 LE - Can I assign inputs from my computer? muffinly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-08-2012 07:52 PM
Sequential assign to midi & inputs Riccardo Corbari Tips & Tricks 5 02-20-2010 01:02 PM
digi002 as generic digital audio interface kbruff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-13-2006 01:18 PM
Logic Pro physical inputs assign w/HD Riccardo Corbari Pro Tools TDM Systems (Mac) 0 01-04-2005 04:34 AM
