Old 03-06-2013, 06:11 AM
Accius08 Accius08 is offline
Default MBox 3 - ASIO Drivers not working
Hi, I've been having trouble with my ASIO drivers for my MBox 3 recently. On both my laptop and my desktop (running Windows 7 and 8 respectively), I am unable to select Avid MBox ASIO as an output in any DAW or audio program. I am still able to use WASAPI/DX/MME modes, but when I try to select ASIO, every program tells me there is nothing connected.
I find it strange that at the same time, both my laptop and desktop independently had the same issue. I've reinstalled drivers on both to no luck. I've also tried installing the drivers on a friend's Macbook Pro, which was able to properly use both outputs. I'm trying to find another windows to test it on.
Could this be a hardware problem? Or an issue with the newest drivers? I'm just curious as to whether it is a common problem, because I haven't been able to find any references to the issue anywhere.
Cheers for any help offered!
Old 03-06-2013, 03:09 PM
SKI SKI is offline
Default Re: MBox 3 - ASIO Drivers not working
Does this include PT, meaning is PT unable to use the interface as well or just programs that try to use the ASIO?
URBAN MUSIC-
(Hip Hop and R&B)
Old 03-06-2013, 10:49 PM
PT isn't able to use the interface either.
I just borrowed a friend's PC running Win7, and installed the drivers, and ASIO was working fine, which means it has to be something on my computers - perhaps running an older driver version might help.
Old 03-07-2013, 11:04 AM
SKI SKI is offline
Have you let Windows (or anything else) make any updates on the two computers with issues?
I would probably take the Win7 machine and do an Avid uninstall then reinstall PT, be sure to connect the mBox only when the installation calls for it.
URBAN MUSIC-
(Hip Hop and R&B)
8.0.3 ASIO Drivers not working lennieh Pro Tools TDM Systems (Win) 14 02-02-2010 05:40 AM
Asio drivers and mbox please help slyxxx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-01-2004 11:25 AM
Mbox ASIO drivers rickthestick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-28-2004 08:59 PM
asio drivers for mbox in mac os 9.2.2?? rocamadour 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-27-2003 09:04 PM
mbox asio drivers? Frank S 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 05-22-2002 12:45 PM
