Old 10-02-2012, 01:30 PM
DelChivo DelChivo is offline
Unhappy MBox mountain lion drivers not working
Hi!
I've just updated to a mountain lion 10.8.2 OS; and the new drivers for the third generation mbox are not working. The software don't recognizes the device's I/O as active ones. I've just updated to PT10.
I guess the drivers are for older mountain lion versions.
Any idea?
Old 10-02-2012, 02:25 PM
Default Re: MBox mountain lion drivers not working
The Mbox control panel crashes too...
Old 10-03-2012, 02:13 PM
lancemcv lancemcv is offline
I am running MT 10.8.2 and PT 10.3 with the latest MBox Pro driver no issues here. Hold down the N key when launching pro tools and see if you can then select the mbox as the interface. If not you may want to try to do an uninstall of PT and drivers and then start over. The mbox mixer should run fine mine does.
Old 10-03-2012, 02:36 PM
jasonthurley's Avatar
jasonthurley jasonthurley is offline
Have you downloaded the current drivers? What computer are you using? Did the MBox work on this computer before??
http://avid.force.com/pkb/articles/e...nload/en379411
Old 10-03-2012, 04:09 PM
tristan klein tristan klein is offline
almost the same problem here. working fine with pro tools, but no way to open the control panel, il crashes whatever happens.
www.tristanklein.com
Old 10-03-2012, 09:19 PM
DigiTechSupt's Avatar
Question Re: MBox mountain lion drivers not working
Which Mbox is this?
I installed the 1.1.2 driver for an Mbox Mini on a iMac with 10.8.2 and it shows up correctly in Audio MIDI Setup, and the Control Panel opens fine.
Did you run the Uninstaller for the previous version before installing the ML version?
Avid Audio Tech Support
Support FAQ
Old 10-04-2012, 01:54 AM
Mbox pro 3rd for me. I ran the uninstaller , device turned off...
Old 10-04-2012, 09:24 AM
here's the crash report...
https://www.dropbox.com/s/kpnv61jpti...el%20error.rtf
Old 10-04-2012, 12:57 PM
RandB RandB is offline
I spoke this morning with Avid Audio tech support concerning the DAE error -6001 that I was receiving (see other thread).
Here's the deal:
You're exactly right. The latest drivers for older Digidesign-branded hardware devices DO NOT WORK WITH MOUNTAIN LION. (Funny, but the 10.3.1 software works with Mountain Lion, but they don't bother to tell you beforehand that your drivers WON'T work with ML. Earth to Avid: It might be helpful to make this information public before people start uninstalling their old versions of Pro Tools. smh).
Anyway, if you have one of the newer Avid-branded (black) MBox devices, or a third party device (such as the Apogee Duet 2, which I have), these WILL work just fine on Mountain Lion with Pro Tools.
Old 10-04-2012, 01:30 PM
Post Re: MBox mountain lion drivers not working
Originally Posted by tristan klein View Post
Thanks for the crash report! Passing it on to Engineering.
Support FAQ
MBox Pro 3 Mountain Lion Drivers jryser macOS 8 09-04-2013 09:03 AM
It's December and still no Mountain Lion drivers for mBox 2! bad jitter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-10-2013 09:05 AM
Mountain Lion Drivers for Mbox 2 Pro Avid Technical Alerts 0 01-09-2013 02:38 PM
11R Drivers for Mountain Lion available skyko Eleven Rack 1 10-03-2012 01:08 PM
OS X Mountain Lion Drivers? AZG Eleven Rack 2 08-14-2012 02:17 PM
