Old 11-09-2019, 09:59 AM
bifbangpow bifbangpow is offline
Default PT Crashing when I try to open a particular session
Hi. I'm running PT 11.3 on a PC. Every time I try to open a particular session it crashes. How do I open the session without any active plugins? I already tried holding down shift while selecting and opening the session but that didn't seem to do anything.
Is there something else I can try?
It opens other sessions just fine.
my specs:
Zbook G2
Intel processor core i7 vPro
Windows 7
ProTools 11.3.1
Scarlett Focusrite
+ Saving to External Harddrive
-Strawberry Jam Composer/Sound Design by day
-psychedelic-punk by night.
http://WeAreTheMayCompany.com
Old 11-09-2019, 01:25 PM
Default Re: PT Crashing when I try to open a particular session
You'll need to try that again as that is the command. Maybe its just bad timing? In any case, with PT open, hold SHIFT and double-click the session .ptx icon and keep holding SHIFT until the session opens.
Option #2-if the above does NOT work(IOW, the session does not open), then its probably not a plugin, but a corrupt audio file. In this case, create a new blank session(same sample rate and bit depth) and then use the Import Session Data function and try importing a few tracks at a time. Each time a batch of tracks comes in without a crash, save before grabbing the next batch of tracks. With any luck, you may be able to nail it down to a single track as the culprit
Option #3-same as option 2, BUT change the sample rate(IOW, if original is at 44.1K, make the new one at 48K). Then let PT do SRC(sample rate conversion) as it imports tracks. This re-writing of the audio files might smooth over corruption(it has worked for me in the past, though not every time)
Old 11-09-2019, 07:05 PM
Thank you. I'm working on option 2 now. I finally figured out which track crashes things. but now another midi track is crashing things. The universe just does not want a trombone line in this session.
Going to try option 3
my specs:
Zbook G2
Windows 7
ProTools 11.3.1
Scarlett Focusrite
Pro Tools Crashing On Session Open marff3 Pro Tools 10 4 05-25-2016 01:20 PM
Cannot open any session without crashing. ReachMusicProductions Pro Tools 11 12 10-02-2013 12:59 PM
Pro Tools crashing every time I open a new session Ryan Butler macOS 25 10-12-2012 03:06 PM
Pro Tools 8 crashing when I try to open a session or start a new session AbstractHabitat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-25-2012 05:58 AM
PT crashing on session open Clockwork Studio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 18 08-13-2008 11:19 AM
