Old 05-25-2004, 05:24 PM
The Wiz497 The Wiz497 is offline
Default PTLE user needs help getting connected properly
I'm just getting started in the production world. I have been a dj and now want to get into production and remixing. I'm want to connect my Radium 61 midi controller, MPC 1000, Mo Phatt sound module and mixer with 2 turntables to my Command 8. I want to use my MPC 1000 as my sequencer, not the software. I have attempted to connect everything myself but I'm not getting any of the midi sounds nor sound from my mixer and 2 turntables out of my Alesis MK2 monitors. Can anyone help me?
Old 05-26-2004, 12:34 PM
funkdefino funkdefino is offline
Default Re: PTLE user needs help getting connected properly
What you are suggesting is not possible. The command|8 is a control surface with a monitor section. What you need is a real mixing board. If automation is what you desire then I would get a digital mixing board with motorized faders.
I would look into a DM-24
If you want to bypass the computer totaly you are barking up the wrong tree by buying a command|8.
Good Luck!
WOW! What is that a .38?
38, 39 what ever it takes.
Old 05-26-2004, 01:42 PM
Thanks for the help. I understand that the Command 8 is a control surface for PT but it is also a stand alone mixer. Would I still need to get another mixer to get sound output from the midi devices and my turntables and to record into Pro Tools?
Old 05-26-2004, 02:16 PM
kcurry kcurry is offline
No, it's not a stand-alone mixer. It is a stand-alone control surface in the sense that it can be used with non-PT software. There are no channel-inputs on the Command|8, so there's nothing to mix. You are probably thinking of the 002, which it appears can be used as a stand-alone mixer, as well as a controller.
Old 05-26-2004, 03:22 PM
You're right, I'm confusing the Command 8 with the Digi 002. But since the Digi 002 is a mixer, why am I not getting any sound from my midi devices and turntables? What is the correct way to connect my midi controller, mo phatt, mpc 1000 and turntables and mixer?
Old 05-26-2004, 03:50 PM
WOW!
Ok...
Do you own a Digi002 or a Digi002 Rack? or... Did you just buy the Command|8 with no Digi002 Rack or otherwise?
Old 05-26-2004, 04:19 PM
I own a Digi002, not the rack. I was confusing the Command 8 with the 002. I apologize for the confusion, but hey, what do you expect from rookies?
Old 05-26-2004, 06:06 PM
Ok. Good!
I am not familiar with stand alone mode. I have a digi002 rack. I'm not sure why you would want to throw away the software for this purpose, but... to each his own.
I think your questions would be answered in the PTLE forum. Be care full you will get a few laughs, but someone will eventually help you.
http://duc.digidesign.com/postlist.php?Cat=&Board=UBB32
Good Luck!
Old 05-27-2004, 06:09 AM
Is that quote about the .38 in your signature from a film or something?
Old 05-27-2004, 09:38 PM
Yes it's from the movie Mister Mom.
Getting the Virtual Keyboard properly connected driaxx Virtual Instruments 0 10-14-2010 03:48 PM
new user struggling to install pt properly w.assaad General Discussion 0 12-07-2008 05:52 PM
DAE Error 1123 Flex Cable Not Connected Properly IonicBreed Pro Tools TDM Systems (Mac) 3 01-12-2008 08:08 PM
PTLE will not work without hardware connected? rcook349 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-28-2005 02:50 PM
MBox connected but PTLE says NOT connected ludaben 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-05-2004 10:01 PM
