Help: Pro Tools Won\'t Launch -- 6004 error
I’m having a problem with my recently upgraded computer. I have a Digi001 running Pro Tools LE 6.4. and Windows XP cs9 and 6, Service Pack 3.
Upon launching Pro Tools, it gets stuck at “Creating DAE Objects,” whereupon a window pops up proclaiming, "DAE was unable to communicate with the audio hardware. Please save your session and restart your computer. (-6004)" Similar to the problem in this thread: http://duc.digidesign.com/showflat.p...Number=1276705 The Digi 001 and the cable are fine: they work in the other computer, as they have for years. At one point, the DigiTest showed “Bus Master failed,” but presently it’s no longer showing us that failure. Also, we had this problem when running Service Pack 2 – so SP3 is not the problem. Over the past couple weeks, we have tried everything we could think of and have exhausted our options searching every possible thread on this board. Tried all PCI slots; have reinstalled Windows XP and Pro Tools numerous times; Updated the PACE drivers; tried the Dualcore Hotfix (which apparently is now included in Service Pack 3). Searched Digidesign for known incompatibility issues. The Digi error database for ~6004 doesn’t have the answer. Presently: Video card is in a PCIe; Digi card in 1st PCI; 2nd PCI empty; 3rd PCI is SCSI adapter. Using the suggested setup from this duc thread: http://duc.digidesign.com/showflat.p...=5&o=7&fpart=1 I followed these BIOS instructions (and have also tried other variations): How to set up the BIOS on a ASUS P5K Deluxe Wi-Fi with DDR2 1066 for BIOS revision 404. Install WindowsXP at the default BIOS settings, install all of your drivers and run Windows Update. To enter BIOS hit the Delete key while the machine is POSTing. This will take you to the BIOS setup pages. MAIN Page Sata Configuration [ENHANCED] Configure SATA as [IDE] Advanced Page Select [JumperFree Configuration] And make the following changes Dram Timing Control[1067] Set the DRAM Timing control to Manual and verify that the following settings read CAS# Latency [5 DRAM Clocks] RAS# to CAS# Delay [5 DRAM Clocks] RAS# Precharge [5 DRAM Clocks] RAS# Active Time [15DRAM clocks] After verifing you memory is set at the proper timing you can hit ESC and return to the JumperFree Configuration page and set the Dram Timing control back to [AUTO] Select [CPU Configuration] And make the following changes. CPU Ratio Control [AUTO] C1E Suppory [Disabled] Max CPUID Limit [Disabled] Vanderpool Tecnology[Disabled] CPU TM Function [Enabled] Execute Disable Bit [Enabled] PECI [Enabled] Intel SpeedStep [Disabled] Hit ESC and return to the Advanced Page Select Onboard Devices And disable High Definition Audio and anything else your not going to be using... Wireless LAN, Marvell Lan, J-Micron controller ETC. But still, the 6004 error appears. Here’s my Sandra summary: SiSoftware Sandra Processor Model : Intel(R) Pentium(R) Dual CPU E2160 @ 1.80GHz Speed : 1.81GHz Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Dual-Core Internal Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 1MB, ECC, Synchronous, ATC, 4-way, 64 byte line size, 2 threads sharing System System : System manufacturer P5K-E Mainboard : ASUSTeK Computer INC. P5K-E Bus(es) : ISA PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes System BIOS : American Megatrends Inc. 0806 Total Memory : 3.25GB DDR2 Chipset Model : ASUS P35/G33/G31 Processor to I/O Controller Front Side Bus Speed : 4x 201MHz (804MHz) Total Memory : 11.13GB DDR2 Memory Bus Speed : 2x 402MHz (804MHz) Video System Adapter : NVIDIA GeForce 8400 GS (512MB DDR2, PCIe 1.00 x16, PS 3.0, VS 3.0) Physical Storage Devices SEAGATE ST39204LW 9GB (SCSI, SCSI-3, 10016rpm, NCQ) : 8GB (C:) SEAGATE ST39204LW 9GB (SCSI, SCSI-3, 10016rpm, NCQ) : 8GB (D:) Logical Storage Devices Hard Disk (C:) : 8GB (NTFS) @ SEAGATE ST39204LW 9GB (SCSI, SCSI-3, 10016rpm, NCQ) NEW VOLUME (D:) : 8GB (NTFS) @ SEAGATE ST39204LW 9GB (SCSI, SCSI-3, 10016rpm, NCQ) 3.5" 1.44MB (A:) : N/A Peripherals LPC Hub Controller 1 : ASUS (ICH9) LPC Interface Controller LPC Hub Controller 2 : ASUS (ICH9) SMBus Controller USB Controller 1 : ASUS (ICH9) USB Universal Host Controller USB Controller 2 : ASUS (ICH9) USB Universal Host Controller USB Controller 3 : ASUS (ICH9) USB Universal Host Controller USB Controller 4 : ASUS (ICH9) USB2 Enhanced Host Controller USB Controller 5 : ASUS (ICH9) USB Universal Host Controller USB Controller 6 : ASUS (ICH9) USB Universal Host Controller USB Controller 7 : ASUS (ICH9) USB Universal Host Controller USB Controller 8 : ASUS (ICH9) USB2 Enhanced Host Controller System SMBus Controller 1 : Intel 801xx/63xx SMBus Network Services Network Adapter : Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller - Packet Scheduler Miniport (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP (2002) Home 5.01.2600 (Service Pack 3) Platform Compliance : x86 Any suggestions? Is something incompatible here – are other folks using the this CPU with this motherboard and Digi 001? Something we’ve overlooked? I’d greatly appreciate any ideas. Thanks. |
Re: Help: Pro Tools Won\'t Launch -- 6004 error
Bump. Any ideas? I'd be eternally grateful.
Re: Help: Pro Tools Won't Launch -- 6004 error
Sorry for the grave digging but i'm having similar problems - New system (Q6600, IP35 chipset board) and protools is throwing a wobbler with a 6004 error.
But looking around the Digidesign forums and i don't think we're alone on this, a lot of people seem to be having problems with running 001's on newer systems, and so far i can't find a solution |
This error has many possible causes - from bad hardware to incompatible computer (or component) to incompatible plug-ins.
Have you tried the suggestions in the General Troubleshooting thread? Update PACE drivers. Try removing all plug-ins for testing. Disable any extraneous hardware Disable startup items and services Hopefully one of those will give a clue as to where the problem is originating. |
DAE error -6004 anyone? | DAL | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-07-2004 11:33 PM |
G5 DAE error -6004 | salvomix | Pro Tools TDM Systems (Mac) | 0 | 10-04-2003 10:20 AM |
HELP - HD3 DAE Error -6004 | sandlg | Pro Tools TDM Systems (Mac) | 4 | 08-28-2002 06:56 AM |
Error 6004 every time I reopen Pro Tools | el biciclista | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-12-2002 10:25 PM |
Error -6004 Help! | The Log | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-23-2001 03:41 PM |
