Old 02-19-2017, 07:11 AM
metalqueen2000 metalqueen2000 is offline
Default guitar amps
Im trying to cut down the noise in eleven, it says to turn on bypass, which I have getting a lot of noise, not sure if Im not in the right directions in the help.
trying to research it, but not sure if I know the key word to search it out.
using a guitar trying to work on tone, even when searching for youtube videos, when pro tools is on, the noise is coming through everything.
iMac desktop
pro tools 12
interface: behringer xenyx q1202
Old 02-19-2017, 10:41 AM
Default Re: guitar amps
There are so many possible reasons for noise, and so many types of noise, that nobody can offer much help without a lot more detail. Rotate your body and see if you find a position that minimizes noise(if you do find a position, then the noise is likely all around you and the guitar is simply picking up what's in the air). Single-coil pickups are normally noisier than humbuckers. Of course, higher gain amp settings will increase any noise(but in truth, many high-gain presets are actually way over-done and you get bigger guitar sounds with less gain).
Noise can also exist on the AC lines(the outlets) and can come from motors(the fridge, air conditioners, a blow dryer in the the bathroom). Older CRT monitors are noisy, as are many wireless mouse/keyboards. Izotope RX is a good plugin for removing noise in your recordings(something I have to do a lot as commercial buildings in Nashville are pretty notorious for inducing buzzing in guitar and bass tracks).
Old 02-19-2017, 10:52 AM
zedhed's Avatar
zedhed zedhed is offline
Most likely a ground loop issue. As Albee said, it's hard to say what could be the cause with so little information and so many different kinds of common 'noise' variables.
Too much blood in my drugstream
Gigabyte X99 SOC Force Mobo Bios vF6d
Intel Core i7 5930k socket 2011 v3 @ 3.50GHz
32GB DDR4 Crucial RAM
System: Samsung M.2NVME SSD 960 Evo
Record: Samsung M.2NVME SSD 960 Evo
Samples: Samsung SATAlll SSD 840 Pro
Storage: 2x Samsung SATAlll SSD 840 Pro
EVGA GeForce GTX 750 Graphics
PT 11HD (v11.2.1) Omni s/pdif w Eleven Rack
HD 96I/O
Win 8.1 Pro
Old 02-19-2017, 11:54 AM
Carl Lie Carl Lie is offline
All of the above.
Positioning yourself has a lot to do with it. If your playing single coils you need to be extra aware of that.
Curious what input you are using on your interface.
Carl
PT 2018.7 HDX OMNI+HDX8x16 -Mac Pro 12 Cores 48 GB RAM OS 10.12.5 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL-GML -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
Old 02-19-2017, 01:44 PM
We can't even tell if you are talking about the Eleven Plugin or Eleven Rack or what. Much more clear information is needed if you want help.
What guitar? What pickups going into what exact input (are you using an external DI). What is the volume knob setting on the guitar and gain setting on the input/DI (if not using an Eleven Rack).
What kind of noise? hiss (white noise)? 60 Hz hum? If not clear post a recoding.
Does the noise change as you touch the guitar strings, move the guitar around? If sn Eleven Rack is the noise there when you play stand alone with the USB cable to the computer physically disconnected.
What amp models are you using and what gain? What is the entire signal flow from physical pickups through external pedals, interface, all plugins, etc. Screenshots of plugins and settings may help.
built in guitar amps? ksg Pro Tools 9 2 11-23-2011 03:31 AM
Using an AUX Bus for guitar amps sighermike Tips & Tricks 11 05-13-2011 11:58 AM
Guitar Amps... jjhuntfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 23 03-02-2005 07:46 AM
Mic Stands for guitar amps PRS4LIFE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-07-2004 04:07 PM
guitar amps? Reverend Dan Tips & Tricks 20 11-01-2002 11:15 AM
