preference to DISABLE edit mode command "clutch"/toggle from 12.6
More people need to vote for this. PLEASE. Since 12.6, hitting command accidentally while editing super fast moves the edit point inadvertently and is very annoying.
No idea why they made this a permanent change to modifier behavior but 10+ years of muscle memory & accidentally hitting command is driving me crazy. It should at least be an option, and I can't see why this is a useful feature to people that are used to editing extremely fast from previous versions. IMO, any change to where your hand needs to be should not be forced upon people. It causes you to look down or think about what's going on depending what version you use. AVID- modifier behavior really needs to be the same throughout all versions as a lot of us likely goto studios on different PT versions. Please vote on idea scale!! Many have also complained about this slowing down their editing flow. There are duplicate submission but this one is pretty clear: http://protools.ideascale.com/a/dtd/...id/263485-3779 thanks all! |
Re: preference to DISABLE edit mode command "clutch"/toggle from 12.6
It toggles either Grid in Slip or Slip in Grid.
Go back a version or two before the change or up a version as Avid changed it back, IIRC, to legacy behavior.
12.7.1 changed this back??
I was holding off upgrading till it was changed. If so, That's great & thx! |
Not that i know...
http://www.ricardomosca.com Hackintosh, 3,7 GHz 10-Core Intel i9, 64 GB 3200 MHz DDR4, OSX Catalina 10.15.7, PT HDX 2023.9.0, SSL 4040G+, tons of outboard Mac Book M1 Pro, 16GB RAM, OSX 23.6, PT Studio 2023.9.0 |
No it's the same on 12.7.1. Change your grid settings to "1 sample" - it's a workaround I know but it definitely helps when you're working fast.
Avid supposedly fixed this in 12.6.1. From the Release Notes:
Breakpoint Editing Grid Toggle is disabled when adjusting automation, MIDI, or Clip Gain breakpoint controls in Slip Mode to avoid conflict with fine-control editing (PT-221294) Pressing the Command key (Mac) or Control key (Windows) while editing automation and MIDI breakpoints now suppresses Grid mode and enables fine-control editing. This is now consistent with breakpoint editing behavior for Clip Gain. Fine-control editing can be disengaged during mouse-down by releasing the Command key (Mac) or Control key (Windows), and then re-engaged by pressing the Command key (Mac) or Control key (Windows) again (PT-221952) Using the Smart Tool to add a breakpoint on a Clip Gain line no longer incorrectly constrains the breakpoint to the nearest grid line (PT-221919) Fixed multiple automation breakpoint editing inconsistencies with Grabber Tool (PT-221862)
still does it in 12.7.1
extremely annoying! the 1sample grid is a good idea though, thx for that! |
What is the key command for "link track and edit selection"? | jkuehlin | Pro Tools 10 | 5 | 10-21-2023 05:07 AM |
i have a problem with "Pencil Tool". Why it's always in "square mode" ? | ak11_lin | macOS | 6 | 08-25-2013 05:38 AM |
Toggle Track view ("Opt"+"-") doesn't work | LukeFromBerlin | macOS | 3 | 04-01-2012 04:43 AM |
Switching a HD from "transfer only" to "record mode" | BretFarewell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 02-16-2010 12:49 PM |
Switching subwoofer from "discrete mode" to "stereo mode"? | Slerker | Post - Surround - Video | 6 | 02-11-2009 07:04 PM |
