Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 02-22-2021, 06:44 PM
lyman23 lyman23 is offline
Default Automating filter type in RX Voice Denoise causes CPU Spike
When automating filter type in RX Voice Denoise on a track, I reliably get a CPU spike, even on a very light session CPU wise. Does this happen for anyone else?
Thanks!
Old 02-23-2021, 05:23 AM
Default Re: Automating filter type in RX Voice Denoise causes CPU Spike
Thanks!
RX stuff tends to be a cpu muncher when used in PT in realtime. Usual remedy is to do it offline and then bring back into PT (at least for me).
Jack
QAPLA!
Old 02-24-2021, 12:09 PM
Thanks for the reply. Looking at CPU I'm at about 12%, then when I switch automation from surgical to gentile (or the reverse) CPU hits 100% and stops with an error. It's just the switching, not the processing, that is causing the error.
Old 02-24-2021, 02:01 PM
midnightrambler midnightrambler is offline
Yeah I just tried here and it does exactly the same for what it's worth, though I've never tried automating it before.
Old 01-02-2022, 12:54 AM
Sonopolis Sonopolis is offline
Interesting! Thank you! I just ran into the exact same issue. I thought it was that one additional instance of RX7 Voice Denoise but yes, it's automating the filter type.
Can anyone say on what versions of RX this is happening? Was it fixed in RX9?
Old 01-02-2022, 08:35 AM
gives's Avatar
gives gives is offline
There was an update for several of the products in the last week or so. I never know unless I check the Portal App from izotope. Ozone 9 as well. The update said bug fixes.
Latest Update: 9.11.1
Released: December 22, 2021
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
Automating Rate values with AIR Filter Gate djhogan AAX Plug-ins 0 10-18-2020 05:58 PM
iZotope Denoise and Multichannel files thecrew Post - Surround - Video 2 02-22-2013 09:52 PM
Creating Voice 'Filter'? RTD Tips & Tricks 5 09-24-2010 10:54 AM
What plugin do you use for a telephone voice type of effect? DJ Hellfire Tips & Tricks 23 12-23-2008 07:05 AM
voice type - mike combination wonderfall 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 05-03-2004 07:55 AM
