Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 11-24-2020, 10:14 AM
senghor senghor is offline
Default When I quit PT 2020 - it automatically restart itself
Hi!
I have a problem w/ Pro Tools 2020.
When I quit a session I save, quit the session and then Pro Tools. Pro Tools quits normally. BUT automatically restart itself!
What may be the problem?
Thanks.
Win11 Pro
Intel i7-12700K @3,6GHz, RAM 32GB
UAD Apollo and pre-amps, Pro Tools 2023
lots of plugins
Old 11-24-2020, 11:17 AM
Default Re: When I quit PT 2020 - it automatically restart itself
Lots of reports on DUC of past problems like this. You should probably be starting there. e.g. http://duc.avid.com/showthread.php?t=406849
And unless its something as specific as Command 8 drivers or similar I suspect (always suspect) plugins. You can look for crash files and check what is at the end of each Pro Tools log file (e.g. Pro Tools may be failing to really shut down OK at the very end).
Old 11-24-2020, 07:32 PM
take77 take77 is offline
The causes can vary but the times I've experienced this on my Windows system it's because of some Nomad Factory plugins.
Workaround for that: Deactivate the track or remove the plugin before shut down.
How to uninstall Pro Tools 2020.11 and revert to 2020.9.1 ArKay99 macOS 10 02-27-2021 02:41 PM
Avid Control App Rollback (2020.5 to 2020.3) budster Avid S1, S3, Dock and Control App 2 06-09-2020 11:01 AM
Pro Tools (2020.3) on MacBook Air 2020 compatibility pellekuipers Pro Tools 2020 1 04-04-2020 08:01 AM
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
002R causes computer to restart automatically amzijackson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-24-2005 01:09 PM
