MIDI Recording Not Working
Odd issue here with recording MIDI data:
Whether from an Instrument track or whether using a MIDI track to trigger an Instrument track, nothing's recording. I can hear the Instrument when triggered by a MIDI track but cannot hear the Instrument track if I'm trying to trigger it from itself. This has always worked for me, either way, in the past. I'm wondering if I've unknowingly changed my Prefs somehow? Each track is record enabled when I'm attempting this. |
Re: MIDI Recording Not Working
i just setup a blank session just as you have yours Setup in your Pictures ... i get sound instantly ... please try in a blank session .. here is the session file in Dropbox if you would like to see if you get sound out of My Test Session - if a Test blank session Built on Your system, is still NOT working on your Session .. https://www.dropbox.com/s/awjtj0symi...0.ptx.zip?dl=0
Hi John!
Thanks so much for your reply. I followed your instructions (I hope) but not getting the desired result Here's a screenshot so you can let me know if I've done what you've recommended correctly. As per your template . . . Thank you! I'd kinda like to resolve this by actually knowing what went wrong rather than having a magical fix that leaves me in the dark, so to speak lol! Cheers! e |
Sorry, forgot to push the "Upload" button :P
John,
Your template works fine.(Thank you!) I can't seem to figure out the diff though between your and mine. |
recording to usb drive and it´s working. Or is it...? | arvid.lind | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 01-24-2010 04:53 AM |
MIDI Questions On IMPORTING MIDI & Recording MIDI Pro Tools LE 7.4 | Michaeldante | MIDI | 3 | 03-27-2009 05:42 PM |
Midi recording - I hear no audio, I am new to midi recording | Peter Roberts | MIDI | 13 | 08-19-2007 03:15 PM |
Recording / working with 96K | convert | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-24-2007 09:01 PM |
Midi stop working in the middle of recording!!! | Freeze | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-20-2005 11:42 AM |
