Old 02-01-2020, 07:34 PM
Kbiastre Kbiastre is offline
Default Some bus paths could not be mapped to their previous output paths.
I'm running a recently updated Protools version 2019.10.0 on a mid 2015 MacBook Pro, OS High Sierra 10.13.6.
My interface is a Saffire Pro 40 (Firewire). The Saffire Mix Control software version is 3.7.
After updating to PT 2019.10.0, I packed up my gear and moved to a new studio, so I had not yet fired it up, until tonight. I got a message “Some bus paths could not be mapped to their previous output paths.” (See Picture #1).
When I turned all my gear on, there was power to everything, I opened a previous session to play, but the audio was coming from my MacBook Pro speakers. I have no audio coming from my interface and monitors that are plugged into my interface. I assume it has to do with the bus paths issue.
I updated my Saffire Mix Control software, rebooted everything, and still got the same bus path message.
Can anyone help me figure out why this is happening and what I can do to fix it? I see in I/O Setup there appears to be a way to delete/build new paths (Picture #2), but I have no idea how to do that. There’s a DEFAULT button but I didn’t click on it.
Thanks very much.
File Type: jpg Screen Shot 2020-02-01 at 8.59.57 PM.jpg (63.6 KB, 0 views)
File Type: jpg Screen Shot 2020-02-01 at 9.00.25 PM.jpg (58.3 KB, 0 views)
Old 02-01-2020, 09:27 PM
john1192 john1192 is offline
Default Re: Some bus paths could not be mapped to their previous output paths.
you could open Pro Tools while holding the Option Key if on a Mac... i think it is ALT on PC, this will allow you to choose your Interface (Saffire) ..
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 02-02-2020, 01:13 AM
Southsidemusic's Avatar
Hold down the N key when launching PT and when the popup window comes up choose your interface and load up PT and see if that helps.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 02-02-2020, 04:44 AM
Kbiastre:
In addition to what's written above I suggest taking a look at the User's Guide (aka The Manual) chapter 6 page 58 in the section 'I/O Setup Buttons'. There it describes the 4 buttons related to path setups. Specifically for the 'default' button I quote:
"Default Button Resets a path type to its default path configuration, depending on the physical hardware I/O you are using and how your hardware is configured.
Option-click (Mac) or Alt-click (Windows) the Default button to restore defaults to paths in all pages of the I/O Setup."
This is from the manual for PT 2019.6
Jack
QAPLA!
Old 02-02-2020, 03:31 PM
what was i smoking ... "N" key yes ... i do this all the time .. thx for the correction ..
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
"Some paths dropped, only mono and stereo paths supported" LSNY Pro Tools 12 3 08-22-2017 05:40 PM
Assigning multiple Output Paths w3ird Tips & Tricks 11 07-11-2017 09:47 AM
PT 12.2 not importing multiple output paths Goombot Pro Tools 12 0 10-31-2015 11:17 AM
Stereo HD Native Low Latency monitor paths are a no go with active surround paths? vieris Pro Tools 12 3 07-27-2015 06:07 PM
Question about Sub Paths and Main paths. oulablank 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-15-2009 12:15 PM
