Kontakt - find previous version preset?
I'm loading a session that has Kontakt 4 instruments loaded. I have Kontakt 5 installed. Is there a way I can find out what the of the previous instrument preset were loaded so I can load them in version 5?
Re: Kontakt - find previous version preset?
Your message makes no sense - I think you left something out.
Reinstall kontakt 4. Keep them both on your machine. Guitar Rig does the same thing. You have to keep the plugins for session compatibility. You can manually transfer your settings from version 4 into 5 while both plugins are open in your session.
2012 Mac Mini i7 2.6Ghz, 16GB RAM, 250GB SSD, OS 10.8.4, 003R, PT10.3.4, Midi I/O and late 08 15" Macbook Pro 2.4GHz, 4GB RAM, OS 10.8.4, Mbox2, PT10.3.4 |
If you haven't got version 4, I believe the version of Kontakt 5 released in the last week or so will automatically replace Kontakt 4 instances. Not tried it myself though yet.
Dave Marsden UK |
Updating Kontakt didn't work. Looks like I'm installing version 4 (what I was trying to avoid). Thanks for you help.
You're wanting saved presets that you created, like eq settings, envelopes, etc. right? The file extension for these is .nkp
On the mac they should be located in: Library -> application support -> native instruments -> kontakt 4 On the pc I think it's program files-> common files -> native instruments -> kontakt 4 Basically you just copy the ones you want, and paste them into the same folder(s) for kontakt 5. Or as others have suggested, you might want to keep both versions installed. It's also noteworthy that once you save a .nki file from kontakt 5, it can no longer be opened with kontakt 4.
- John If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound? |
saving in previous version | Andres Gonzalez | Pro Tools TDM Systems (Win) | 1 | 04-24-2010 04:57 PM |
PT 8.03 feels much better than the previous version | garnoil | Post - Surround - Video | 8 | 01-02-2010 04:54 PM |
Pt 8 and previous version plug in help. | omons2273 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-31-2009 07:02 PM |
Reverting to Previous Version | aliengroover | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-07-2004 09:11 PM |
