Old 02-17-2011, 07:13 PM
hammster hammster is offline
Default Trouble with Strike 1.5 Install from download
I purchased and downloaded Strike 1.5 Upgrade (I was previously licensed to 1.0). I got the iLok key fine, and downloaded all files.
I have them all in a single directory on my "C" drive, and unzip all the content into a folder. I run the "content location" program, and it sets fine.
I start the Strike installer, and it goes fine until it gets to the point where it asks for "Strike Content 1" folder. I select the folder where my content is, but I get an error stating "setup could not find a valid file in the path". It doesn't tell me what sort of file it is looking for, so I'm not sure what it needs. I try to cancel the error and continue install, but the installer doesn't allow that.
I tried the install a second time, and wanted to skip the content install. I figure I could just point to the content afterward. However, the isntaller won't allow me the uncheck "content" - I'm forced to install both.
I was really hoping to get this going tonight, and verion 1 installed without problems. Kind of frustrated.
My system info:
Windows 7 64 bit
6GB RAM, and 1TB drive
Digi 003
Pro Tools LE 8.0.3 running fine
Thanks for any help you can provide.
Hammster
Old 11-04-2011, 04:47 PM
Brian in Charlotte Brian in Charlotte is offline
Default Re: Trouble with Strike 1.5 Install from download
I've had a Strike install issue as well - downloaded all 4 .dmg and the system says "Successful" but when I launch PT1- it says "Pro Tools could not load the following plug-ins because no valid authorization could be found, the iLok key was not connected or the plug-in was damaged". I already downloaded the auths to my iLok and verified they are there. Weird!
The Voice of Brian
Mac Studio M1 Max, Focusrite Clarett2Pre, Sennheiser 416, sometimes Beta Tester for iZotope
Old 11-05-2011, 12:14 AM
@ndy's Avatar
@ndy @ndy is offline
Same here.
2012 Mac Mini i7 2.6Ghz, 16GB RAM, 250GB SSD, OS 10.8.4, 003R, PT10.3.4, Midi I/O and late 08 15" Macbook Pro 2.4GHz, 4GB RAM, OS 10.8.4, Mbox2, PT10.3.4
Old 11-05-2011, 12:52 AM
@ndy's Avatar
I ran the PT10 installer again and it's fixed. DTS needs to make a sticky about this.
Old 11-05-2011, 06:39 AM
jre90 jre90 is offline
worked for me!
Old 11-05-2011, 06:54 AM
When you guys ran the PT10 installer again, did you uninstall it first and then reinstall? I might give it a try if so.
The Voice of Brian
Old 11-05-2011, 07:55 AM
SUCCESS!!!!!!!! Hammster, I uninstalled PT10 and reinstalled. It came right up!!! I do see it flashing a note in the bottom of Strike saying I need to "run the SetContentLocation application"......I see what's up with that now. But hopefully this will fix your issue as well.
The Voice of Brian
Download trouble Councillor Getting Started 1 09-10-2013 12:26 PM
opening download of strike on mac paul sandberg Virtual Instruments 3 11-12-2011 01:41 PM
8.04 LE Download Trouble lovesciencemusic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 07-10-2010 09:33 AM
Strike download for PT 8 ? Majorek Virtual Instruments 2 06-08-2009 12:15 PM
Strike Trouble tclopet Virtual Instruments 2 01-06-2007 06:38 AM
