Old 06-05-2009, 11:44 AM
blackmatchstick blackmatchstick is offline
Exclamation Talkback
Hey how u all doin,
i need help once again, not much but little.
i have got a new Command|8 controller,
all i would like to know how do i get a talk back with the below given setup
003 Rack
Protools 7.4
Command|8
i need the simple and the best way, if it can be routed thru command|8
then it would be great else no issues....
and i am not interested to buy any new hardware at all for this talk back thing
but yes i do have a microphone
Please reply asap i am stuck in the middle of a contact and i dont want to loose it just for this little thing...
and thanks to all in advance who would be helping me out....
Blackmatchstick
Mac Pro 12 core | MacbookPro 15" |Protools 10 | Logic Pro 9 | Reason 5.0 | Abelton Live 9 | Traktor Dj |
Old 06-05-2009, 02:11 PM
jgehring jgehring is offline
Default Re: Talkback
For talkback I just set up an extra audio track called "TB" and keep a mic plugged into one of the inputs on my 002 on the desk. Route that input to the TB track and when you want to say something to the talent just hit the record enable button.
Pro Tools 2019.6 on Windows 10
UA Apollo 8
Old 06-05-2009, 04:11 PM
O.G. Killa's Avatar
O.G. Killa O.G. Killa is offline
I have a similar way of doing it without eating up a voice. Use a Mono Aux track. Mute and unmute to talk.
I usually setup a "trigger" inside protools (which will eat up an additional voice) to turn the TB mic on and off as you stop and start protools, that way it isn't "on" when protools is playing or recording. And is always "on" when protools is stopped.
To do the trigger thing... create a mono audio track. Select something like 10 minutes within the track (or something large enough where it extends past the last note of the song). Open up the Audiosuite Noise Generator. Create a 1KHz Sine at 0dB (or -2dB or -10dB, whatever you want). The sine wave will then fill the space of the selection on the new track. This sine wave track now becomes your "trigger" track. Assign it's output to bus 32 (or some other unused bus). Put a Digi Dyn/Compressor 3 on the Aux. Set it's Key input to bus 32 (or the bus you used) and click on the little button that looks like a key on the right side of the plugin. Pull the threshold all the way down as far as it will go. Set the ratio as high as it will go. Attack time of maybe 1ms or less, release time of 1second or so. leave any other settings at their default.
When you hit play or record, the sine wave triggers the compressor and pulls the volume of the talkback mic down so far that you can't hear it at all. When you stop it will come back up and everyone can hear it.
If you have a separate headphone mix for the musicians coming out A 3-4. You can assign the talkback mic aux to output A3-4 instead of A 1-2 and then you won't have to worry about the mic feeding back in the control room. If not then you'll have to manually turn down the control room level on the C|8.
Old 06-05-2009, 05:40 PM
I seem to remember a 3rd party talkback plugin that would mute the talkback mic/track whenever the transport was engaged. I just use a Presonus Central Station with a footswitch(built-in talkback mic)
Old 06-05-2009, 06:39 PM
Craig F Craig F is offline
from Massey
http://www.smassey.com/plugin.html
Thank you,
Craig
Old 06-06-2009, 05:46 AM
Thanks for the reply....
don't u think doing the same thing wit an Aux channel would be more
better cuz then we would be on a safer side of by mistake recording the talk back.
but what i really wanted to know can we drive the talk back from the command |8
Blackmatchstick
Old 06-06-2009, 12:39 PM
O.G. Killa's Avatar
what do you mean by "drive"? There is no talkback button on the command 8, but if you jump to the TB track you can mute and unmute it on the command|8. It's not as integrated as the C|24's talkback..but you can still make it work.
Old 06-07-2009, 02:12 AM
well by the term "Drive" i ment to route the signal thru command|8, and i guess your idea to automate the talkback is nice ill try that out...
thanks for te reply
Blackmatchstick
Old 06-07-2009, 04:59 AM
smfelton's Avatar
smfelton smfelton is offline
The Behringer MON800 Stereo Monitor Mixer, is a simple solution that works well, I have a footswitch connected to operate it.
 OSX 10.11.5, PT 12.5, iConnectAudio4+, Axe FX 2 XL+, Music Man Majesty
Source Talkback AAX gets auto talkback MIKEROPHONICS Post - Surround - Video 0 11-20-2013 08:15 AM
C24 talkback Scott Goldberg ICON & C|24 0 12-01-2005 11:37 PM
Best way to set up a talkback? ukeist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-22-2005 11:53 AM
Talkback mic rfreeman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-05-2001 12:44 AM
Talkback David Sutton General Discussion 7 11-22-1999 07:20 AM
