Pro Tools consolidates files in aiff-c
Hello everybody,
Do you have any idea why Pro Tools saves consolidated files in the aiff-c format instead of aiff? Does it have to do with me opening up an old 5.1 project? Cause all the files in the project are aiff, so why does pro tools save them as aiff-c when consolidating? Thanks in advance. |
Re: Pro Tools consolidates files in aiff-c
When Macs made the transition from Power-PC to Intel architecture, the endianness of the native file formats changed too. The original AIFF (Power-PC) format is big endian. This changed to little endian and Apple gave it the AIFF-C Sowt designation to distinguish it from the big endian format. So while your old project has true big endian AIFF files, any more work done with it on the Intel platform will generate little endian AIFF-C files.
Can I simply set the project to .wav even though it was originally set to aiff and have it consolidate into the selected format? Or will this cause file / conversion issues?
If you want to make everything uniform, then start out by using the "Save Session Copy" command in the file menu. Make a copy of the session and include all the media files choosing .wav as the new file format. Once Pro Tools has made the copy, open it and check to make sure everything copied properly. Now, any new files you record will be the same format.
Yes, Pro Tools now supports multiple audio file formats per session so you can just change to .wav format in the session setup and it will save new files in that format to whatever the sample rate and bit depth are set to in the Pro Tools session.
Wav files in a Pro Tools Aiff session Does it Matter? | bryced87 | macOS | 1 | 06-21-2015 11:55 AM |
Utility for transferring pro tools files into wav or AIFF (outside of Pro Tools) | dfen827 | macOS | 4 | 12-12-2013 06:53 PM |
AIFF files on PC | RFUSED33874 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-19-2007 10:03 PM |
Will AIFF Files work in Pro Tools? | digimike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-16-2006 06:02 AM |
HELP! Aiff files unrecognizeable by Pro Tools | sfaudiogeek | Pro Tools TDM Systems (Mac) | 2 | 12-04-2005 09:21 AM |
