Old 09-16-2010, 06:05 AM
ianstonehouse ianstonehouse is offline
Default Flux IRCAM Spat plug-in
I've just bought and installed the new Flux IRCAM Spat plug-in and I'm having problems figuring out how to setup and/or select more than a basic mono or stereo input into a 7.1 version of the plug-in. The manual seems to indicate that you can have multiple sources going into one instance of such a plug-in but doesn't explain exactly how one does this in - for example - ProTools 7, which I'm using on a Mac.
The system I'm using is a custom 8 speakers in a circle + sub setup, and I'm routing the eight 7.1 outputs from the plug-in to the 8 speakers (in the plug-in output matrix) and using a separate sub send in PT via a bussed Aux.
Does anyone know how to do this, or know of any online documentation or user forum that can shed some light on how to achieve this?
Thanks.
Old 11-02-2010, 01:45 PM
speakon speakon is offline
Default Re: Flux IRCAM Spat plug-in
Hi Ian.
does the i/o configuration in pro tools automatically configure itself once a Spat multi-channel i/o configuration has been selected within the plugin itself, or do you still manually need to go into the pro tools i/o windows and configure the stereo busses (l.e) for FL, FR C, LFE SL, SR etc
Old 11-07-2010, 02:45 PM
the process in Neyrincks mix 51 is to buss the output of every track (you want to mix in surround) to the input of the 5.1 mixer plugin that gets inserted on any aux track. Surround panners are inserted on aux copies of all tracks so they are post the faders.
seeing as spat has the panning and mixing in one package would it not be simply a process of inserting multiple copies the spat plugin (as an insert) on individual tracks rather than bussing the output of all tracks to one instance of spat?
Flux ircam reverb and session reverb klaukholm Buy & Sell 7 10-23-2013 12:42 PM
FS: Flux Ircam Verb V3, Altiverb, ReVibe II, Iris, MC77, Focusrite d2/d3, Vytis Buy & Sell 2 10-23-2013 11:55 AM
FS: Flux IRCAM Verb, Izotope Iris, TL Space, MC77 Vytis Buy & Sell 2 06-21-2013 04:33 PM
FS : Flux Ircam Hear and Verb Session HolB Buy & Sell 0 02-07-2013 02:47 PM
is anybody using IRCAM SPAT ??? made Pro Tools 10 0 08-31-2012 04:13 AM
