#2491
Re: The Allenstein Quadzilla Machine
thanks, I'll try that out again. I downloaded that (I think) from Tyan, it contained to setups, one for TMS ans one for TMC, but in all readme's it didn't list the S2927 and, when I tried it briefly it said, cannot read data ... I'll give it another more thorough try. Cheers, - J * Update * you can download TSM 2.24 from http://www.tyan.de/archive/support/h...utilities.html and after this you can install patch 2.24 from same website. This should work with S2927. CPU temperature should be OK, if it will not be higher then 70°C. If you have more then 70°C, then you should think about how to improve the cooling. Above 90°C you should switch off quickly.
Digi 002 Mbox 1 Digi001 (retired to shelf) Asus P5K Premium v3, Q6600, 2x2GB Corsair Tyan Thunder n3600B (S2927A2NRF) 2xAMD OPTERON 2214 2.2GHZ Win XP Pro SP3 |
#2492
Hi Guys:
ALright, so Im trying to get together all of the components to build me a quadzilla. I just cant seem to get my hand on the power supply (OCZ PowerStream OCZ520ADJSLI ATX, BTX, EPS12V 520W Power Supply) Also guys, can I fit 4 Western Digital Raptor 10,000RPM drives on the Asus K8N DL? I am totally new to computer assembly so could anyone suggest any alternatives to the power supply that are easy to get? really appreciate your help |
#2493
Re: Allenstein OctaPC and Quadzilla Machine *update*
I'm a newbie here considering building a "Quadzilla" myself or going with a professional solution such as pcAudio's custom DAWs. Just for grins, I put together a pcAudio rack mounted 8 core system (see below). Can someone in the DUC give me an estimate as to the PTLE performance benchmarks one might expect with such a system. Thanks.... Dual Processor Rackmount Dual Intel Xeon E5310 quad core 1.6GHz Tyan Dual Xeon Motherboard $2,870.00 Memory 4GB DDR2-667 ECC (4 x 1GB) $660.00 VGA Card NVIDIA Geforce 7600GS 512MB DVI/DVI $80.00 Optical Drive 1 NEC 18x Dual Layer DVD Burner $0.00 Optical Drive 2 NEC 18x Dual Layer DVD Burner $50.00 Primary Hard Drive 80GB SATA II (7200rpm : 8MB cache) $5.00 Audio Hard Drive 150GB SATA (10k RPM: 16MB cache) (Audio) $330.00 Extra Hard Drive 1 250GB SATA II (7200rpm : 8MB cache) (Data) $105.00 Floppy Floppy Drive $10.00 Modem 56K DataFax Modem $25.00 Operating System Windows XP Professional $0.00 Total $4,135.00 |
#2494
Hi there! i'm new to the DUC,
yes i did D_VERB test with the MBOX 2 and my K8N-DL Quad 2* AMD 265 ASUS EN6600 2 G of CM72SD1024RLP-3200 1 * Maxtor 40 GB 7200 RPM (System Drive) 1 * Samsung 120 GM 7200 RPM (Audio) 1* LG DVD-writer Win XP pro with MBox 2, and now i'm scratching my head, the damn thing will only do 96 D-VERBs with all Processors set to max...and 1024... anyone any ideas what i [bleep] up? Sorry for my Genglish i'm from germany Ingwer |
#2495
Hi rockinrude,
Looks like you're running both PT and audio from your system drive. You really need a dedicated hard drive for your audio. Dave
Intel Core 2 Duo E6600/Asus P5W DH Deluxe/Nexus NX-5000/2 X 1GB CORSAIR PC2 6400/WD 80 & 250 GB Hard Drives/GeForce 7600GT/Lite-On CDRW/AcoustiCase 360/2-120mm AcoustiFans/XP Pro SP2/Mbox LE 7.3.1 |
#2496
#2497
Hi all, just built a quad and wanted to post some interesting results from initial dverb tests. My quad is as follows:
Tyan S2927 dual socket F 2x Opteron 2212 2.0 GHz w/ Zalman AM2 coolers, Arctic Silver 5 4x Kingston 1 GB DDR2 SDRAM ECC Registered 667 XFX 7600GS 256MB dual DVI Seagate Barracuda ES 320 SATA Samsung DVD-RW SATA NEC black floppy Antec Titan 550 case w/ 550w TruePower PSU So here's the interesting part. I did the first dverb test with an Mbox 2 Pro, and was able to get 155 dverbs (31 tracks w/ 5 dverbs each), recorded 5+ min. I wanted to compare with an old Mbox1, thinking I would get a similar discrepancy as what Phobia saw above, like 6 or 7 dverbs less. But instead I was only able to get 137 dverbs (27 tracks w/ 5 dverbs each, 2 dverbs on track 28). Then I realized that Phobia's results were with Opteron 2214's at 2.2 GHz !! I was almost able to match his 002 on dual 2214 results with Mbox 2 Pro on dual 2212! So, my theory is that maybe the driver for the Mbox 2 Pro (and possibly the 003) results in more dverb capability than the 002. Not sure. I need to borrow a 002 to compare with the Mbox 2 Pro on the same system. Suffice it to say, I'm quite pleased with the performance on dual 2212's. EDIT: got 2 more dverbs on the Mbox1 by using a different USB port. |
#2498
Cheers,
this thread rocks. I am sorry that I occupy thread space - but - I have no usefull info on Asus mobo. - J
#2499
what bios version for the k8n-dl are you using?? should be 1008. have you checked that the ram is in the right slots i think i have it posted on the first page of this thread?? i would start here, this is the area where most people have had there problems.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 3-6-18) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#2500
Hi guitardom
at the moment i use BIOS Version 1009, could tht be problem, should i downgrade it to 1008?(theres also Version 1010 available...). I used the Driver from the CD since i read that there where problems with the Tyanboard and the drivers, didn't read that about the Asusboard... on the net i found the following drivers: ForceWare_8421_WHQL_Certified nForce4_AMD_Edition_WHQL_Certified K8NDL1008 are these the right ones? should i install XP new and format the HD new? thanks for such qick help to all og you this forum is great! Ingwer |
Intel Core i7 2.0GHz Quad-Core Processor or Intel Core i7 2.7GHz Dual-Core Processor? | okodub | Pro Tools 9 | 3 | 09-23-2011 07:33 AM |
Single core vs. dual core vs. quad core | John Peeples | Tips & Tricks | 9 | 11-07-2007 03:28 PM |
APPLE MAC PRO or The Allenstein "Quadzilla" Machin | hws | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 27 | 03-05-2007 11:06 PM |
MAC PRO or The Allenstein "Quadzilla" Machine ???? | hws | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 09-26-2006 11:53 AM |
Opteron 165 Dual-Core, upgrading my Allenstein! | RSSstudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 02-01-2006 08:14 PM |
