Old 12-31-2018, 03:40 PM
Fritz Fritz is offline
Default eucon firmware downgrade
can the current firmware be downgraded to work with PT10?
"Do not fear mistakes. There are none."
Miles Davis
Old 01-01-2019, 02:10 AM
EddieJones's Avatar
Default Re: eucon firmware downgrade
Yes, unless you use the iPad Control App. http://euphonix.avid.com/login.php
Old 01-01-2019, 05:18 AM
is there downgrade process a pita or fairly straight forward?
Miles Davis
Old 01-01-2019, 05:40 AM
EddieJones's Avatar
down grading from 18.3 on you just run the installer and select to uninstall everything including prefs. Then install the old version of your choice. To uninstall earlier versions uninstall and then follow these instructions http://avid.force.com/pkb/articles/e...nstall-for-Mac
Old 01-01-2019, 08:33 AM
thanks again Eddie.
Miles Davis
Old 01-02-2019, 03:08 PM
any idea how to find the date of manufacture of the EuCon silver?
Concerned about the life cycle of the faders and LCD screen and whether parts are still available?
It appears to me that these devices could be 10 years old.
Miles Davis
Old 01-03-2019, 12:31 PM
EddieJones's Avatar
They could be over 10 years old. Faders are still available...screens may have burn in by now and might be a problem fixing.
Eucon 3.2.2 installer error + firmware downwards compatible with eucon 3.1 deauditievedienst Artist Series 2 07-14-2021 09:33 AM
MBox 2 - Firmware Reset (Downgrade) adam79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-13-2013 09:09 PM
Downgrade Native firmware 10 to 9? Hugh-H Pro Tools HDX & HD Native Systems (Mac) 2 04-12-2013 09:53 AM
Digi 003 firmware downgrade? apples 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-07-2012 01:18 PM
Firmware downgrade 192 I/O Mac Pro Intel PT 7.2.1 Max44 Pro Tools TDM Systems (Mac) 3 10-11-2006 01:51 PM
