S3 resets and reconnect again
Anyone else seeing this, as the track plays maybe after 60 secs or so the S3 resets (all screens blank and faders go down). Then everything goes back to the previous settings. This happenes in less than half a second. It also resets the PT Control to track view. No effect to audio, Very strange?
Thoughts? PT HD12.4 with Econ 3.3.2 on El Capitan Cheers Scotsman |
Re: S3 resets and reconnect again
My guess would be your iPad is losing connection.
does it happen w/o iPad?
Mac Studio, 32GB, PTHD2022.7, OS 12.5.1, S3, Transport, (EuCon 2022.4.0.78) LIO-8 BlackmagicDesign UltraMonitor3G Reaper 6.66, Fireface UCX MacbookPro M1Pro PTHD2021.12 MacOS12.1 BlackmagicDesign UltraMonitor3G MOTU 24Ao AppleTB3toTB2->AppleTB2->Ethernet->AVB |
Thanks, will try it without the iPad and see if it stops happening.
Cheers Scotsman |
It has not been happening over the last few days, so all seem well now.
Haven't changed anything so maybe it was just a blip with my wifi? Cheers Scotsman |
Yeah, could be Wifi related. If I connect to Wifi whilst running the S3, it will lose connection. It's fine as long as I connect first, and then open EuControl, whilst keeping the Wifi connected.
also, the ethernet connections on the S3 are very iffy, especially if you put the S3 in an angle (I mean lower at the front and higher at the back in order to be able to read the displays). I tried lots of different ethernet cables but ended up using some rubber bands to keep the ethernet cable from losing connection. It's the same on both ethernet ports, so I guess there's nothing wrong with my particular S3, it's just the 'design'
Lost Connection To S3 when unplugging the router for EcX - not been able to reconnect | Karel Noon | VENUE Live Sound Systems | 3 | 06-15-2015 10:05 PM |
Protools 8 HD reconnect hardware issue | pscpro15 | Getting Started | 8 | 04-19-2015 05:16 AM |
Workaround how to reconnect MC Control (Macke) | djmichaelwenz | Artist Series | 0 | 10-01-2013 08:56 PM |
MBox2Pro - Boot:No Sound; Disconnect/Reconnect Firewire: Get Sound; Why? | mav9999 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-23-2009 08:48 PM |
Mbox wont playback unless reconnect USB cable!!!! | el matador | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-16-2003 01:51 AM |
