I'm remixing a song I recorded last year. The tracks for this project were mostly frozen.
In four instances, I had used a limiter plug-in on an aux effects track, D16 Group's Frontier. When I opened the session file, the plug-in was listed as 'not present in the plug-ins folder.' When I unfroze those four tracks and tried to activate that plug-in, I got the error "The plug-in could not be made active because the plug-in is not present in the plug-ins folder." The plug-in is indeed in the plug-ins folder. This is a new machine and a new PT installation. I downloaded and installed new versions of all plug-ins at the time of the install. When this cropped up, I tried uninstalling the new version (1.2) and reinstalling the version that was used in these tracks (1.0). I thought that maybe PT wasn't seeing it because it's a new version. I got the same error. Not a huge problem, but I'm wondering why this might be happening. I can load a new instance, but it never sees the instances that are there. Any ideas? Thanks for any help anyone can provide. dg
Be Quiet Pure Base 600 case * Core i5-12600K * Gigabyte Z690 UD AX * 32 GB G.Skill Ripjaws DDR4 * 2X HP DreamColor Z24x G2 displays * NVIDIA GeForce GTX 960 * Samsung 980 boot drive * Samsung 870 EVO PT projects drive * Samsung 860 EVO PT archive drive * Novation Impulse 49 MIDI * PreSonus Studio 26c interface * PreSonus Bluetube V2 preamp * PreSonus HP4 headphone amp * JBL LR 305 monitors * Sennheiser HD 650 headphones * Windows 10 Pro 64 21H2, Pro Tools 2022.7.0 |
Did you try trashing prefs, especially to force Pro Tools to rebuild the plugin index/cache?
I don't know the plugin but is there any possibility there is something askew here say with different versions or different behavior for mono/multichannel vs stereo (i.e. are your tests on the same track type?) Was the 1.0 version you installed really the same as before, like same format, not using a compatibility wrapper etc. Like any chance it was RTAS or AAX-32 on Windows 10 and now it's tryin got use AAX-64? There might be some incompatibility there... like some of the plugins that broke compatibility from RTAS to AAX something the vendor support might know off the top of their heads. And no I'm not even sure this plugin was ever in RTAS, or you were ever using it in RTAS even if it was. Last edited by Darryl Ramm; 09-25-2022 at 06:16 PM. |
![]() Quote:
Thanks for your help. I'll contact the vendor.
Sounds like a problem for D16 Group - I'd contact their support.
http://www.richbreen.com ---------------------------------------- MacPro 5,1 Dual Hex, OS 10.14.6, PT 2022.6 HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock. Also running a 2013 nMP / HDX / S6 |
Just my opinion, but I would not leave tracks frozen for long periods. If you are going to put a session away for weeks or months, I would use track commit, or commit up to the last plugin and keep the original track in view but inactive. Track Freeze looks great on paper, but has bitten many folks right in the ASSets
Gigabyte X79/intel i7 3930K, 32GB RAM, HD/Native, 192 IO https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
![]() Quote:
My old system was so slow that I had to freeze just about everything to do anything.
![]() Quote:
![]() Quote:
Bob Without a song The day would never end |
![]() Quote:
I've never used commit, only freeze to whatever insert makes the most sense. I've only gone through 2 of the 20-odd songs I's working on. So far I haven't had any problems with previously frozen tracks other than the Frontier limiter issue. At this point I'm not freezing anything (and haven't had to yet). Thanks again. dg
My long-time guitar tech in NYC (who is still my guitar tech though I'm no longer in NYC) always preached that I should NEVER listen to guys on YouTube because "it's some guy sitting in his boxers in his grandmother's basement."
What good is "Save Copy In..." options "Session Plug-in Settings Folder" and "Root"? | ZerglingPhilosophy | Getting Started | 1 | 09-02-2022 04:43 PM |
"One or more tracks contain plug-ins not in your plug-in folder Xpand!2 " | Gyrobob | Pro Tools | First Discussion | 3 | 09-07-2018 08:07 AM |
Moving plug-ins to the "Plug-Ins (Unused)" folder | lschultziv | AAX Plug-ins | 2 | 08-05-2014 10:18 AM |
Import session data... please break out "plug in settings" and "plug in automation" | yeloocevad | Pro Tools TDM Systems (Mac) | 19 | 10-05-2011 02:04 PM |
Message "Pro tools with tdm requires the tdm mixer plug-in in the plugins folder" | Alexei Zaitsev | Pro Tools TDM Systems (Win) | 0 | 01-10-2009 04:48 AM |
