Old 01-26-2016, 09:08 AM
bucha bucha is offline
Default Cycle Plugin Windows in PT
Hey guys,
Does anyone know the way I can display in PT any plugins of an attentioned track by pressing a key (or a softkey) or how I can cycle through inserts of my attentioned track once i've pressed the "plugin window" soft key ?
Thanks !
Old 01-26-2016, 05:09 PM
EddieJones's Avatar
Default Re: Cycle Plugin Windows in PT
I'm not sure there a way, you would have to go into the plugin and then back out.
Old 01-27-2016, 03:46 AM
Hmmm … Too bad.
It would have been quite cool to display (in PT) any plugin you're working on (in expand mode particularly) by pressing a key (and close this plugin window with the same key).
Old 01-27-2016, 07:16 PM
EddieJones's Avatar
There are plans (maybe even in the next release) to add EQ and DYN cycling. Pressing the EQ button more than once would take you to the next EQ in the chain, if there were more than 2, pressing a 3rd time would show the 3rd EQ. Likewise with Dynamics. We could do the same with Inserts but that would take away seeing the list of plugins on the knobs and then picking the one you want.
Old 01-27-2016, 07:27 PM
YYR123's Avatar
YYR123 YYR123 is offline
Originally Posted by EddieJones View Post
There are plans (maybe even in the next release) to add EQ and DYN cycling. Pressing the EQ button more than once would take you to the next EQ in the chain, if there were more than 2, pressing a 3rd time would show the 3rd EQ. Likewise with Dynamics..
Cool, make it so number 1....pump that ride
Daniel
Old 01-28-2016, 02:56 AM
Cycling into your EQs and DYNs would be great !
But, thinking about the expand zone, it would be nice to be able to cycle without returning to the EQ or DYN keys of the track you attentioned.
The list of the plugins in Inserts view is a very good thing, it's just the fact that you have to click on your insert in PT to be able to see it, which a bit boring.
So just adding a little key to display the plug your working on would be great !
Speaking about the Insert view, It would also be great to be able to get into writing all the automation enabled parameters of a plugin only by touching his knob !
And Last but not least, being able to copy and paste settings of plugins parameters in insert view (ICON style) would be awesome !
Thank you very much Eddie, it feels great to be heard on the development of this great product !
Old 01-28-2016, 07:44 PM
EddieJones's Avatar
All these things are on the list to do.... ;-)
Old 02-22-2016, 09:30 AM
Tstein Tstein is offline
+1 for EQ/DYN cycling
003 life cycle Xone Pro Tools 9 3 02-22-2011 04:56 AM
60 cycle hum savanasdad 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-26-2006 06:19 PM
Product Cycle??? Drew Mazurek General Discussion 1 11-03-2000 11:48 AM
60 cycle hum indieo General Discussion 3 10-04-2000 09:15 AM
Cycle playback... PeeTee Tips & Tricks 3 06-07-2000 11:06 PM
