Old 03-21-2011, 10:27 AM
77pro 77pro is offline
Default daisy-chaining FW HD
A friend is using PT9 on a macbook pro and a presonus firestudio with good results so far.
I've convinced him to get an external FW drive for sessions....is it still recomended to put the FW drive between computer and interface?
I know they used to recomend that config. for the 002 and 003.
Thanks for any info.
003r/i7-930/LE 8.0.1 cs2 on xp
Old 03-21-2011, 10:34 AM
KMcK KMcK is offline
Default Re: daisy-chaining FW HD
Yes, but even better if you get an express34 Firewire card and run either the interface or the HD off of that.
Old 03-21-2011, 10:48 AM
Thanks for the info........
So run one off the express card and the other from the built-in port ?
Old 03-21-2011, 11:49 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Yes. I have an express card and it works well with my FW800 drives.
I would use the build-in FW port to go directly to the interface. Hook any other FW drives to the express card.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 03-21-2011, 12:09 PM
Thanks for the info!!
Old 03-21-2011, 04:59 PM
AfterJohn AfterJohn is offline
I have an eSATA ExpressCard in my MBP for my drives and it kicks ass!
MacBook Pro 2.2 GHz Core i7 4GB RAM 10.8.5, PT 10.3.4, Waves v9.1, Duet 2
redtuxedo.com
milkmoneyconsulting.com
mindexpansiontechnology.com
Old 03-21-2011, 05:14 PM
Dism Dism is offline
Same.
eSATA beats out FW every time, and no need to jam up the FW bus or daisychain.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 03-21-2011, 07:03 PM
LanceK LanceK is offline
I also use the eSATA express card and it does kick FW's as_
Old 03-21-2011, 08:08 PM
gtomassetti's Avatar
gtomassetti gtomassetti is offline
I was thinking of getting an express34 FW card, but the eSATA card sounds pretty slick. Just to be sure, something like the Sonnet Tempo SATA edge ExpressCard/34 would connect up to my Glyph drive? The SATA card and a 1-meter cable would actually cost just less than a FW/USB express34 card.
Mobile: 17" MBP (2.66 GHz Intel Core i7, 8 GB RAM, 10.10.5), True Systems Precision 8, MH LIO-8
Home: Mac Pro (2x2.4 GHz Quad-Core Intel Xeon "Westmere", 32 GB RAM; 10.10.5; boot drive 960 GB Mercury Accelsior_E2 PCIe card), OMNI, MH ULN-2, MOTU 8pre
PT HDN 12.6; REAPER 5+ (32 & 64-bit); PreSonus Studio One 3 Pro, Central Station Plus, and FaderPort
WAY too many plugins and VIs; WaveLab 8.5; Sound Forge Pro
Finale 2014d, 2014.5, 25.2
Old 03-22-2011, 09:38 AM
My FW interface drives run around 75 MB/sec while they do around 125 MB/sec with eSATA. So if you are looking for the fastest interface, yes, eSATA. But I don't know what difference it will make with your actual sessions. Of course faster is always better. But a FW400 drive will support 32 tracks.
I've seen many quad interfaces on drives now so they come with USB, FW400, FW800 and eSATA.
Park
New MacBook Pro FW daisy-chaining wlaer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-08-2009 02:04 AM
Daisy Chaining? SkiFiend 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 09-30-2008 07:22 PM
FW daisy chaining clausiii 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-18-2008 09:57 AM
FW daisy chaining clausiii Pro Tools M-Powered (Mac) 1 03-18-2008 08:50 AM
Daisy chaining I/Os RexTrax Pro Tools TDM Systems (Mac) 2 08-06-2007 04:08 PM
