Old 07-07-2010, 09:11 AM
JamesSosound JamesSosound is offline
Default Audio region labelling techniques for large speech recording projects
The company I work for are embarking on a project recording Speech for a AAA computer game for the first time. We will need to be able to label audio regions in between takes during recording as efficiently as possible. Pausing recording, then double clicking a region, copying from a script then pasting the text back in to Pro Tools would be quite time consuming for thousands of files. Is there a more straightforward solution using a plugin or feature of Pro Tools I am currently unaware of that will ease this process. Would anybody be happy to shed light on standard industry practice for this type of process.
Many thanks for your help,
James
Old 07-07-2010, 09:26 AM
nucelar's Avatar
nucelar nucelar is offline
Default Re: Audio region labelling techniques for large speech recording projects
Take a look at voXover. It is not Pro Tools-based but it fits these kind of jobs perfectly.
Once the recording session is done, you can of course import the files to PT for further tweaking
http://www.audiofile-engineering.com/voxover/
Old 07-07-2010, 09:46 AM
clusterer clusterer is offline
I´ve done this kind of work with the combination of Quickeys and an excel sheet.
I´m weired:
The excel-sheet had titles for each cue/take BELOW each other. so I recorded a few work steps with quickeys..:
first - in the excel-sheet - I recorded the double click of the first title/cue, then command+c,
then the "down arrow key" to select the next title (the titles of course have to be below each other).
next recording was command+tab (to change to pro tools). there I hit "enter" (set marker); then command+v (to paste the name of the first title/cue); then enter again; then I recorded the PT-short-cut to move the curser forward/NUDGE for 30 seconds (nudge must be changed to 10 seconds or anything you prefer) .
next step was change over to excel (command+tab)again. the next/following title in the sheet should be selected now.
so with that - you got a "loop". give this fu*#ing quickey a name and a shortcut.. and let it work for you.
when you´ve finished the recordings you have to record a quickey that allows you to copy the marker-names into the regions regarding to the markers..
äahhmmmm... hm...
(sorry for bad english)
cheers,
gregor
G. Rasek - recording engineer - www.overdub.at - european VO talents via source-connect - PTHD
Old 07-07-2010, 09:50 AM
uh.. looks way more elegant then mine procedure:))
Old 07-08-2010, 01:28 AM
mjryder1 mjryder1 is offline
I've done a bit of this before using the strip silence function on protools in the edit drop down menu.
This allows you to duplicate and name lots of regions in 1 go but is only useful if they need sequential names. (eg: VO1, VO2, VO3, etc)
Don't know if thats any use? if you got them named like this though you could give a folder of them to someone to rename somewhere else therefore not clogging up you studio.
Old 07-08-2010, 02:55 AM
Thank you all for your excellent suggestions.
The Voxover software fits the bill perfectly and is a very worthwhile investment for only £250. I have been using the trial version this morning, very straightforward and versatile. Problem solved.
Thanks again.
James
Old 08-25-2010, 04:18 AM
JLIT JLIT is offline
Would you mind posting your Quickey shortcut file for me to try this one out? I use excel as well for the same type of process and would really like to give this a go Thanks!
Would you mind posting your quickey shortcut file? I really want to give this one a go.
I´m weired:
äahhmmmm... hm...
cheers,
gregor
Old 08-25-2010, 10:11 AM
Magnetic Magnetic is offline
+1 for VoxOver.
Old 08-25-2010, 04:02 PM
mikevarela mikevarela is offline
edicue works as well. I haven't used it but there are video on the website... some of the work is done automatically from cue sheets, however it might be a little overboard for this type of work.
NuanceTone.com
HTML code is On
Audio Recording Problem in Pro Tools 9 - Large Wavelengths even though input is fine miabugg Pro Tools 9 3 10-03-2012 01:00 PM
Bus-powered G-Drive: can it run large audio projects? David Topple 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-22-2010 06:46 AM
Recommended vocal speech recording settings proactive General Discussion 2 10-01-2008 10:24 AM
Speech Audio Quality in Movies H.R. Toad General Discussion 8 01-17-2003 06:31 PM
Splitting large projects Sparks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-18-2002 10:42 AM
