Old 01-08-2008, 09:50 AM
Jeremy Lock Jeremy Lock is offline
Default Preferences
I am running PT7.3 on a HD3 PC system with a D-Control console. My problem is that whenever I restart Protools, certain system preferances are not being saved. ie mixing and editing preferances. Does anyone know why this is happening? Our older system (PT7.3 HD1 on a PC with a Procontrol) has never exhibited this problem.
Thanks in anticipation.
Jeremy
Old 01-08-2008, 01:10 PM
Felix Rost Felix Rost is offline
Default Re: Preferences
I have an LE system that looses preferences very often, sometimes only some, sometimes all. The HD system I use does loose Prefs only after serious crashes.
I find loosing preferences VERY annoying -especially after having to delete them- MY prefs seem to be so different from the default, also column sizes in browsers and the order of those etc..
My list of most silly PT prefs:
-edit insertion follows scrub shuttle NOT selected?
-solo mode: latch, why not X-OR?
-column sizes: valuable screen estate gets wasted by blank spaces in columns e.g. Channels, Size, Sample Rate, Bit-Depth, ... there wont be ever any number to fill it.
-and yes, I think every stereo track should be Inverse Pan Linked by default..
sorry to capture your thread... ;-)
Felix
Old 01-08-2008, 01:57 PM
originalscottyg originalscottyg is online now
I have a work around that works after crashes/trashing prefs, but may not address the Original Poster's issue...
After a preference trash/reboot/repair permissions/etc...
I setup everything the way I want, then make a copy of JUST the ProTools 7.x Preferences file in a separate location.
Next time I have to trash prefs, I copy that "Clean" pref file into the prefs folder and regain many (not all) of my settings
Hope that helps.
Scott Gatteño
Yessian
"Violence is the last refuge of the incompetent" - Salvor Hardin
Old 01-08-2008, 04:11 PM
tomlowd tomlowd is offline
i have the same problem with my pc based hd4 d command. only happens about once a month though.... a
doesn't seem to happen on macs...
Old 01-11-2008, 07:50 AM
Kigh Kigh is offline
Hi Jeremy,
Is your OS system language set to english or any other language? (probably english in UK?!)
I had the same problem. The only thing that helped was setting my OS language from german to english (system settings).
Now everything is fine! Maybe switching back and forth between two languages may help? (restarts)
The non-english users with same preferences problems could try that way.
Kai
Old 01-11-2008, 07:56 AM
Sorry Jeremy,
My advice refers to Mac Systems only.
Kai
HTML code is On
PT 8 Preferences on Mac sricabla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-02-2013 10:15 AM
Preferences Jeremy Lock Post - Surround - Video 0 01-08-2008 09:50 AM
Preferences mookie36 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-15-2007 01:10 AM
Preferences thin ice Pro Tools TDM Systems (Mac) 5 11-23-2003 01:35 PM
Preferences Slypolk Digidesign Hardware & Software 2 02-16-2000 05:21 PM
