  #21
Old 11-20-2019, 03:13 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Default Re: Bug in new video engine 2019.10
Originally Posted by henningaround View Post
I have seen nothing of the errors above. Been working with 2019.10 now for a week or two with Decklink Studio2 and Aja Kona3G Card. Always QuickTime Movies with DNxHD36 Full HD. Have you guys tried different combinations of the video drivers (Aja or Balckmagic depending on your cards...)? I think it's version 10.11.2 of the Blackmagic driver on a macOS 10.12.6 here or Aja 15.0.1 on macOS 10.12.6.
Session is not too big. Stereo TV Mix on a HDX2 or HDnative system with ~ 150 voices used.
Native video, no drivers needed!!
IMDB
  #22
Old 11-22-2019, 11:19 PM
smurfyou smurfyou is offline
I have not experienced this. DNxHD MXF video, 1080p through BM Decklink.
~Will
  #23
Old 11-23-2019, 06:34 AM
henningaround henningaround is offline
Is it a native Desktop Video issue only then?
  #24
Old 12-02-2019, 02:45 PM
RossH RossH is offline
Having the same issue here since upgrading to 2019.10. Video loops small sections, usually if I work on a short section of audio for a bit, then start playback, the video will loop the short section I was working on. Bizarre. Video will also freeze on a single frame, while timeline continues playback.
Blackmagic Decklink Intensity Pro card, 11.3 drivers.
QuickTime Prores Proxy videos, and MXF's from Adobe Premiere CC 2020.
Hope they can fix this.
PT Ultimate 2019.10 // Mac Pro 2012 // High Sierra 10.13.6 // BlackMagic DeckLink Intensity Pro
  #25
Old 12-10-2019, 05:32 AM
Farhoof's Avatar
Farhoof Farhoof is offline
I'm seeing this as well now,
not random loops though, it seems related to selection where I copy/pasted to or wrote automation to in preview mode. The loop is exactly a certain selection I made.
PT 2019.10 Ultimate, HDX, MacOS 10.12.6, Decklink driver 10.11.2, DNx36 .mov.
  #26
Old 12-19-2019, 03:22 PM
gwhatley's Avatar
gwhatley gwhatley is offline
Bump - as this one is a show-stopper if you have clients, and disruptive enough to workflow even without people over your shoulder.
Of course I'm working in an earlier version when I have clients, but am curious:
1. if anyone has seen this officially addressed
2. if most people are NOT having this issue
3. if the current update .12 solves the problem (though it is not listed specifically in the bug fixes)
Thanks,
G.
Sent from my LG-H872 using Tapatalk
Garrard Whatley
Seismic Post Audio
Post Audio for Film and Television
System/Hardware Info
IMDb credits
  #27
Old 12-19-2019, 04:33 PM
reichman's Avatar
reichman reichman is offline
#2. I haven’t seen this issue since I posted over a month ago. Sierra, 2019.10, AJA T-Tap, ProRes proxy video. All good.
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
Dubway Studios
  #28
Old 12-20-2019, 05:15 PM
seanmccoy seanmccoy is offline
I experienced this looping bug for the first time today. Disabling and enabling the Video Engine once cleared it up. Still pretty disconcerting, though. Guess I'll give 2019.12 a try after all.
ADK Core i7 4.20, 32GB RAM, W10 Pro, PT HD 2020.3, HD Native, OMNI, Digi 192, AJA Kona LHi, UAD-2 Octo; Mac Pro 8-core 2.67, 32GB RAM, High Sierra 10.13, Logic Pro 10.4.8, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU LP32, Pro Tools 2019.10
  #29
Old 12-29-2019, 10:41 PM
mandal mandal is offline
http://duc.avid.com/showthread.php?t=407807
Win10 Home (64-bit), Avid OMNI PCIe, Pro Tools Ultimate 2019.12, Avid HEAT, i7 processor, 16GB RAM, Samsung SSD 840 EVO (system disk), Siemens SSD840 PRO (session disk), Dell 43" 4K LED P4317Q
  #30
Old 01-01-2020, 06:23 AM
mik mik is offline
After installation, reset the prefs ans so on, 2019.10 seems to work on my system (high Sierra HDX). In editing process all was ok.
But after the session becomes complex, i began to have black screens after ten minutes, then after one or two minutes of playback.
Then the video begins to lag sometimes, stop or turns to black.
It was really unusable.
I switched back to 2019.5 and everything went smooth again.
I tried different codecs, DNX36 of course, but also Prores, or H264, but nothing really worked.
HTML code is On
Problem enabling video engine 2019.6 Lydbildet Windows 12 04-02-2020 10:24 AM
'The Video Engine reported and error' message when trying to play any video zerothrills Pro Tools 12 9 12-08-2019 10:37 PM
PT 2019 same video problems garnoil Pro Tools 2019 12 05-12-2019 03:50 PM
Video Engine Fail "Waiting for the video engine to launch" oscar_wonderboy macOS 5 08-14-2018 01:22 AM
Video Engine not working.. crashing when i load in a video to PT11 sarahsherlock Pro Tools 11 5 08-16-2014 12:35 AM
