192 lightpipe optical out set-up, digital monitoring
I'de really appreciate some help with this
pt 8.0.4 192i/o win xp im trying to connect my 192i/o with digital card to my logitech digital stereo speakers with a lightpipe optical cable.I use to monitor this way with my 003, was quite an easy set up. i think im missing something obvious, not really sure how to setup my i\o or HardWare in HD. i followed these instructions and tried to come out via optical enclosure (not adat, digital card), but to no avail For Output of Pro Tools using Optical port on Enclosure section of 192 I/O: 1) In Pro Tools > Setups > HW setup > Doesn't matter what's set for Digital Tab. 2) Main tab: Set Digital Format is set to AES or S/PDIF. 3) Main Tab: Set analog outputs 9 - 16 to Optical 1 - 2 (ADAT), Optical 3 - 4 (ADAT) etc. 4) In Pro Tools > Setups > I/O Setups: Click on Output Tab. Press "Default" button. Now, all inputs will all show up as A 1 - 16. 5) Set output of audio tracks to A 9 - 16 for output through the optical connection of Enclosure Optical Port. i think im having a tuff time with # 5. it appears that #5 was also set up by default. outputs 9-16 already appear to have optical outs set from 9-16. i guess what im asking is. is this the proper procedure for what im trying to do? all help is appreciated |
Re: 192 lightpipe optical out set-up, digital monitoring
IIRC, only the enclosure optical is switchable between ADAT and S/PDIF. I'm betting you need optical S/PDIF to feed the speakers. In the Hardware Setup main tab, digital format needs to be Optical S/PDIF. Now there should only be one enclosure optical path to choose from. That's the one you assign and use for your monitor routing.
Optical lightpipe help please | brickroadstudio | Pro Tools HDX & HD Native Systems (Mac) | 0 | 04-15-2011 11:42 PM |
192 lightpipe optical out set-up, digital monitoring | grendizer | Pro Tools TDM Systems (Win) | 0 | 09-07-2010 05:40 PM |
003 and Digimax, lightpipe optical troubles!! (HELP!) | hw2nw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-17-2007 09:01 AM |
ADAT optical in via Lightpipe and i get nothing | commonwall | Pro Tools TDM Systems (Mac) | 3 | 11-14-2004 12:22 PM |
Lost optical / ADAT / lightpipe I/O ! | pklem | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-15-2004 03:22 PM |
