Old 10-04-2006, 01:51 PM
dane2df dane2df is offline
Default Mastering Issue (After Bounces)
Hey everybody, I just mixed a tv program that had 3 stereos track, really simple and all...I was using a Finalplug plugin and it sounded fine with no clipping. But I needed to export each track (regular bounce) and after that, imported to final cut and when I played, it was cliping...does anyone know what happened? Just to make sure, I opened a new PT session and imported all bounces and the clipping appear also...sorry if my English sucks, but I'm from Brazil.
thanks
Old 10-04-2006, 08:56 PM
jre3132 jre3132 is offline
Default Re: Mastering Issue (After Bounces)
If you import any commercial cd into protools it will clip. I don't really know why this is, but it always happens.
I would just make sure you limit (if you dont, just that it doesn't clip as you did). If you're good on the output, you're ok for playback.
Mac Pro 3.7 Quad Core Intel
Mac OS X 10.13.2
PT Ultimate HDX 2019.10
64GB RAM
HDX I/O 16x16 Analog
HDX I/O 8x8x8
Old 10-05-2006, 02:56 AM
imi imi is offline
I believe ProTools shows 3 full level samples in a row as clipping, so if there is 0 db brickwall limiting you may well see this as clipping.
The other (probably obvious) cause is not panning the imported stereo track 100% L/R which will sum the tracks and clip the master bus.
Hope this helps
Old 10-05-2006, 03:16 AM
req06 req06 is offline
My suggestion is maybe you exported/bounced each individual track with the final plug over the master fader. so that each stereo channel is limited. when you line these up together they will each be limited to 0db or whatver you set finalplug to limit to, when plaaying them back together they will cli pthe master bus as they were limited separately and not as a composite mix.
just re bounce everything minus final plug. line up, then put final plug over the stems as the last step before delivering
G5 dp 2.0Ghz, 2.5 gb RAM/ G4 Powerbook 15" 1.33mhz, 2gb RAM/ 002r/Lacie D2 FW800/PTLE 7.4
Old 10-05-2006, 03:19 AM
Paul Maunder Paul Maunder is offline
Protools (and any other program) seems to import a few tenths of a db hotter than the cd is.
It doesn't. Pro Tools (all all other similar applications for that matter), just import exactly what's on the disc without any gain change. The vast majority of modern CD's are compressed to a ridiculous extent, and have peak levels which constantly hit full scale (0dBfs). Most applications indicate full scale digital as clipping.
Mastering help? .... or is it a mix issue? TDub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 02-11-2011 05:48 AM
clipping/input level issue - mastering wendyrjames Pro Tools TDM Systems (Mac) 2 06-17-2009 02:48 PM
A mastering issue: low output levels? foxlemieux Pro Tools TDM Systems (Mac) 26 04-08-2003 01:24 PM
Mastering singles for radio with new Waves Mastering suite. Peter Duemmler Pro Tools TDM Systems (Mac) 14 06-21-2002 05:14 PM
Mastering singles for radio with new Waves Mastering suite. Dimension Zero Tips & Tricks 0 06-15-2002 12:32 AM
