CPU is holding off USB audio
it says to remove plug ins, tracks or increase buffer size and iv'e done all these things. can anyone help me with this.
Re: CPU is holding off USB audio
first of all you have given the very least amount of details about your problem
it's like asking your doctor to diagnose an ailment by just showing up in his office and having a seat.... second I'll just take a guess and see what happens Not Supported USB 2.0 Hard Drives USB hard drives are NOT recommended or supported for use as recording drives. Limited testing has shown that performance with USB drives is inferior to that of FireWire drives.
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
Im having the same problem. Im running 6.9.2 on a g4 tower with dual 1 gig processors. when I try to play back the session I get the 9136 error and it stops playing. I also have reason open, and am using a few synths. the session uses 8 tracks other than the reason all the plugins are protools, reverb, delay etc...
Thanks pughking |
Anyone would need more rig details to respond to these posts. Computer model, PT version, OS version, RAM stats, etc....please...a little more info as to what the problem is....bright minds and suggestions await you...
J Fred in Nashville
G4 MDD Dual 1.42, 2 gig RAM, MAC OS 10.4.11, PT 7.3.1cs8, 192 I/O, Gibson Stereo 79RT |
Im running pt 6.9.2 on a g4 tower with dual 1 gig processors. I have 1.5 gig of ram. OS 10.4.11.
if it is a g4 1ghz and you use the build in usb,
it is usb 1.1 with a data rate of 1 (!) MB/s. ..... regards
foley artist , soundeditor |
i'm using 7.3 on a 160 gig macbook with osx leopard. recording on an external hard drive with a mbox 2. running about 10 tracks with only 5 plug ins. playback works some time. but at least half the time i get the -6105 warning.
theDude couldn't help you if you literally put your computer and interface on his desktop. It is most likely their interface not your CPU. Enhance your system again to the best of your knowledge carefully. Most end up disabling their own computer believing this error 6104 6105 9885 ect. is your CPU inefficiency instead of their hardware/interface issues they don't tell you about. Look for a different interface. Good luck.
CPU usage is holding off USB audio | Justin Brandt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 32 | 11-24-2006 02:40 AM |
Please Help! My CPU is holding off USB Audio!?!?! | darg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-20-2005 06:37 PM |
CPU usage is holding of USB audio ? | hrolfur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-11-2004 02:32 PM |
CPU holding off USB audio ( -9136 ) PLEASE HELP! | ElBingo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-29-2003 09:07 AM |
CPU holding off USB audio | Walling1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 07-11-2002 10:10 AM |
