Old 09-24-2004, 05:39 PM
lemix's Avatar
lemix lemix is offline
Default A quick Q, re; drive formatting...
Hi all,
I have a live, off the floor acoustic gig coming up.
The studio's HD Accel computer is on OSX and my client's FW drive was formatted on OS9.
Should I do a full re-format, to be compatible ?
Also, what performance can I expect on a G4 /Dual 1.25Ghz computer hosting an HD Accel II, with 3X 96 IO's ? I'll need to go 96/24 for no more than 18-20 recording tracks at the time...
There will be no plugins used.
Thanx in advance for your responses,
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 09-24-2004, 05:57 PM
Default Re: A quick Q, re; drive formatting...
How long do you need to record for (how long's the show)?
The computer'll be more than fine.. it'll be all about if you need another drive. Formatting instructions are in the Troubleshooting thread in this forum, but I've had no problems using OS 9.2.2 formatted HFS+ drives in OS X.
Whatever you end up with.. you should do a stress test run to make sure the system and drives can record for a sustained period with the max number of tracks... before the gig... especially when using a system which isn't your own and you have no idea how it's set up. If you can't get into the studio for the amount of time required beforehand... make sure that you tell the studio manager what you'll expect of the system before you arrive so they can test it before you get there.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 09-24-2004, 06:12 PM
lemix's Avatar
Thanx Rail,
I'll need to record up to 10 mins/PT session.
Do I need a second FW drive to split the allocation up ?
As I've mentioned 18-20 tracks max.
The studio is where I work. No problem for testing before hand.
again, thank you...
cheers,
Andrew
Old 09-24-2004, 06:33 PM
10 minutes.. you'll be more than fine.
Rail
Platinum Samples
Old 09-24-2004, 06:46 PM
lemix's Avatar
cheers,
Andrew
Old 09-29-2004, 11:12 AM
sukks2bu sukks2bu is offline
Guy, Mac rules.......
Powermac 9600/300 768mg ram OS 9.1.2, PTmix3 V5.1.3, 888/24, Adatbridge, 882/20, PSX-100, BigBen
MacBookPro 1.8ghz 2gig ram OSX tiger, Mbox2 PT V.7
Formatting new drive TheWillies 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-25-2009 03:47 PM
Quick formatting explanation please Gunnell Pro Tools M-Powered (Win) 3 08-07-2007 01:08 AM
Quick formatting explanation please Gunnell Pro Tools M-Powered (Mac) 0 08-06-2007 05:06 AM
Formatting FW Drive with Drive Setup Utility OneMadSon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 06-10-2003 07:49 PM
Drive formatting Reckless Erik Post - Surround - Video 6 12-27-2002 05:05 PM
