Old 02-28-2007, 11:50 AM
Andy Gerome Andy Gerome is offline
Default Help with Mbox 001 - Where is ASIO control panel? *DELETED* *DELETED*
Post deleted by Andy Gerome
Old 02-28-2007, 12:04 PM
JMS40 JMS40 is offline
Default Re: Help with Mbox 001 - Where is ASIO control pan
There is no ASIO control panel in Pro Tools.
The Digi ASIO driver is used outside of Pro Tools to interface with 3rd party ASIO compatible software.
Try opening up your I/O Setup Options in Pro Tools and click on the Default button to see if that sets things straight for you.
Also check the "Default Output" settings there.
Old 02-28-2007, 12:30 PM
Default Re: Help with Mbox 001 - Where is ASIO control pan *DELETED* *DELETED*
Old 02-28-2007, 12:44 PM
That picture is of the ASIO setup panel in Reason. It is shown only as an example to point out that you configure the ASIO driver in the setup options of each individual ASIO capable application.
Each application will have different ASIO setup options.
From the ASIO Driver Usage Guide... just above the image you mention:
Configuring ASIO Driver settings is done in your third party ASIO program. For example, with Propellerhead Reason, click on the ASIO Control Panel.
--Image of Reason Control panel--
Freezes - Turns white - Loss of control 7.1 LE Mbox 1 *DELETED* Andy Gerome 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-12-2008 01:10 PM
Dry Scratchy Faders - Hmmmm..... *DELETED* *DELETED* *DELETED* Table Syrup Records ICON & C|24 0 07-18-2007 08:26 AM
DIGIDESIGN'S SUPPORT IN EUROPE IS TERRIBLE!!!!!!! *DELETED* *DELETED* extratone Pro Tools M-Powered (Win) 10 11-22-2006 05:34 AM
Accel 3 on G5 w/30" Monitor *DELETED* *DELETED* *DELETED* slangification Pro Tools TDM Systems (Mac) 1 12-08-2004 06:41 AM
help with identify beat *DELETED* *DELETED* *DELETED* *DELETED* *DELETED* rafio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-07-2003 04:19 PM
