Old 07-10-2014, 11:23 PM
Alvin Alvin is offline
Default OSX 10.9.4 stops Avid Video Engine [RESOLVED]
If you have updated to OSX 10.9.4 can you try something and let me know if it works.
1. Create a test session (don't use an existing one)
2. Create a new Video Track
3. When Protools asks to start the Avid Video Engine or connect to it say OK - does your Avid video engine start?
4. If you have a session with Video, does the AVE start when you open it?
I accidentally upgraded from 10.9.3 to 10.9.4 thinking it was another App store upgrade and now my session that contains video is rendered useless.
This is on PTHD 11.2 and 11.1.3, Macbook Pro retina, 16GB RAM
Thanks all.
Alvin
Old 07-11-2014, 04:21 AM
dougdi dougdi is offline
Default Re: OSX 10.9.4 stops Avid Video Engine
I am not having that problem and I'm using the same machine you have. Have you repaired disk permissions or trashed the prefs yet?
Old 07-11-2014, 07:27 AM
No, I'll give that a try and come back...thanks
Alvin
Old 07-11-2014, 08:34 AM
This is strange...doesnt work. I even reverted to 10.8.3 and it is the same. That means the only other thing that has changed was upgrading to Eucon 3.1.3 - will try removing that.
Alvin
Old 07-13-2014, 02:31 AM
Issue resolved. I had installed a plug-in called filmconvert which was causing the issue.Removed and now all fine.
Alvin
Avid Video Engine not working in 11.1.3 efisch Post - Surround - Video 26 06-02-2014 01:57 PM
Can't import video "Avid engine not installed"??? garnoil Post - Surround - Video 9 10-08-2012 04:45 PM
AVID video engine playback issue Audio_Vision Pro Tools TDM Systems (Win) 4 04-08-2011 01:09 PM
Avid Video Engine and Midi IO driver Tennyson General Discussion 5 12-27-2010 08:39 PM
Avid video engine not installed... what's up? Helge Krabye Pro Tools TDM Systems (Mac) 2 11-05-2006 08:16 AM
