Cannot use disk device as \"playback\" device Pro-tools 7.4Mac
I'm using a rack 003 on a mac with pro-tools 7.4-latest update with 2 external firewire disks. I've been using a fire wire disk with the volume "protools data" without issue for a good few months on it, I've got a few tracks/demos/ideas recorded on it, great. Today I wanted to add something to one of the tracks, when I tried to open one of the pro-tools tracks I get the error message " This session is saved on a volume set to transfer only. If permitted, set the volumes in question P (playback) or R (record) in this workspace " What has happened to set this volume to a different state than it was in when it's been working fine for a few months as a recording and play back device ? What is the correct mode to set this disk back to (I assume record) and how do I go about setting it ?? Quite confused with this issue out the blue. thanks, Matt. |
Re: Cannot use disk device as \"playback\" device Pro-tools 7.
some times the T/R/P settings switch for some unapparent reason
now if you can not change it back you may have a problem
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
All sorted,
thank you very much for that. Great info. |
I just got myself through a similar situation this morning on my new computer, new external firewire drive and new PTLE version. In my case, I could not write to the external firwire drive...on which I had been reading and writing without incidence for the past several days...since I setup the new system.
A trip to the Workspace page showed that the drive in question had suddenly read-only enabled itself somehow, but I could not simply bump it up to Write operation...the change wouldn't stick. Next stop was Disk utility where I saw that there too, the disk was only read-enabled...and locked. Final stop, selecting the firewire drive icon on my desktop and doing a command-I to see, among other things, ownership and permissions in the Information dialog box. Once there, I could not unlock the drive (by pressing the padlock icon at the lower right-hand corner of that dialog box and entering an administrator password...the padlock icon was grayed-out and not available to me) nor could I change the permissions or its Read-Only status. The next course of action was to eject the Firewire drive and power it down...except that I didn't seem to have the permissions to even eject it. So I just powered the whole system down...including the firewire drive....and then powered it all up again. Once up, the firewire drive mounted and I verified that I still could not change the read-write status in th Pro Tools Workspace. But I then did the Command-I information thing again for the firewire drive...and saw that I could now press on the padlock and unlock it...and make it a Read-Write drive, for myself and for anyone else. Back to Pro Tools and I was now able to set the drive as a Pro Tools Audio/Video Read-Write-Transfer drive. Problem solved...for now at least. The reason for this sudden problem? Not sure, but I suspect it has something to do with the fact that I inadvertently put my computer to sleep last night when I finished work, rather than shutting it down as I normally would...new buttons, new functions. More as it develops. Of a somewhat related nature, since going to the new system I have "developed" a few (and perhaps growing number of) files that are grayed-out and unavailable to me in Pro Tools when I look at then in the file import browser. The files can all be opened normally from the desktop by double-clickng them, or by opening them from other applications....but they can't be imported into Pro Tools on my system. Something is wacked I guess. Everything looks normal and typical for the files when I Command-I them, but they are just out of reach to Pro Tools. I even tried trashing all Pro Tools preferences and the Digidesign Database folders of each drive...but no luck. But I still am loving PTLE 7.4 running on a core 2 duo. Perhaps my apparent permissions problems have been solved in 7.4.2...who knows.
iMac 2.66 GHz (8.1) 320 4 GB RAM OS 10.6.5 500 GB Western Digital My Book Studio FW 800 Pro Tools 9.0 002 |
Pro Tools could not initialize the current playback device (on 10.2.0) | Cosme | macOS | 1 | 07-18-2012 06:45 PM |
Playback Engine Setup, Pro Tools Agg. or the actual device? | Blackwell99 | macOS | 2 | 05-27-2012 04:24 PM |
Pro Tools could not initialize the current playback device | mkpascucci | macOS | 4 | 05-01-2012 04:00 PM |
Pro Tools could not initialize playback device...... | JZProductions | Pro Tools 9 | 2 | 10-10-2011 10:14 PM |
Pro Tools could not initialize the current playback device | johnwesleybarker | macOS | 2 | 01-14-2011 05:52 PM |
