Can you play along with a track without recording?
I have the new digi 02 rack and am running pro tools 6.1. I want to rehearse tracks without having to record them each time. But unless I record enable the track and the record each take I cannot here the audio while playing. Can anyone help. Thanks for your time
Re: Can you play along with a track without record
You don't have to record just because the track is record enabled. Ensure that Low Latency Monitoring is off, if I remember correctly. Sorry, it's been a while. Maybe, I shouldn't have responded. I'm pretty certain this is what you have to do. I don't, personally, use the Low Latency Monitoring feature so I never incur this problem that you are experiencing. Anyway, try it and see.
I’m still on PT 5, and I dont have it in front of me right now, but I guess you want to select "Input only monitoring" in the "operations" menu.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Input only monitoring was the answer! Thanks for your help guys. I really appreciate it!
Thanks Ben, that what I meant.
press option-k
How do I play to a track without recording it? | rickwin7prt8 | Pro Tools M-Powered (Win) | 1 | 08-24-2010 12:08 AM |
When I enable a track to record and then hit 'play' the track will remain silent | Rainerbird | Pro Tools M-Powered (Win) | 2 | 08-07-2009 09:41 PM |
Recording and getting latency when play back the rec track | willl3 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 02-25-2008 12:22 PM |
recording and play midi track | hfd5 | MIDI | 7 | 10-23-2007 08:03 PM |
Can i Play one track while recording another? | calmlikeabom | General Discussion | 8 | 08-23-2002 08:25 AM |
