Old 05-29-2007, 07:44 AM
byronfunk byronfunk is offline
Default Adding MIX cards to PT System
I'm looking to add additional Mix Cards to my PT system. I am currently running a Mix Core card and 2 DSP Farm cards (and also a UAD card) on my Dual 1.42 PowerMac. Can I use all 4 slots for Mix cards? Do the additional cards need to be Farm cards or can I install Core cards to be used as Farm cards? Any issues to look out for? Thanks!
Byron
Old 05-29-2007, 10:18 AM
audiogeek1 audiogeek1 is offline
Default Re: Adding MIX cards to PT System
You can add a mix core card or farm or mix farm cards to your system. I am not sure you could add a D24 core card. I know you can use one with a mix farm. I did this for a long time but not sure you can mix that with the Mix Core card. You can use all available PCI slots as long as they are next to each other. If you need more slots they do sell expansion chasis. This will give you either 7 or 13 more PCI Slots.
Mike
Adding cards to pt9 adam12@nctc.com Windows 3 03-04-2013 12:07 PM
Adding another 888/24 to mix plus system Carbon Filter Digidesign Hardware & Software 26 12-24-2008 09:10 AM
Adding a second LE system to Venue MikeTrahearn VENUE Live Sound Systems 2 12-06-2008 10:31 AM
Adding ram to DIGI 001 system jcress 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-04-2004 07:24 AM
Adding Cards to a PTIII System db8 Tips & Tricks 0 10-06-1999 07:21 PM
