Old 05-23-2007, 09:03 AM
Rowdyb Rowdyb is offline
Default cpu usage error with single track eror -6104
Ok so i've installed 7.1 on an G5 powermac running 10.4.8 and a 1.25gm of ram. intsallation went fine but once i ran it with one, yes just one, audio track it gave me an error and wouldn't play.
error number is -6104 it tells me to increase the buffer which i did to the max and still the same issue. now i've had issues before with digi and i know that some times the error message doesn;t correlate with the right solution
so what do i do now
i've done all the optimization: energy setings, stop spotlight from indexing, removed every usb device except the keyboard and mbox mini
could it be the actually box it self. i've tried a different usb cable aswell
some one save me
Brandon
PS tried re install after a clean uninstall as well
Old 05-23-2007, 09:48 AM
DigiTechSupt's Avatar
Default Re: cpu usage error with single track eror -6104
Which Digidesign hardware are you using?
Avid Audio Tech Support
Support FAQ
Old 05-23-2007, 10:19 AM
I am using an mbox mini
thank you for replying quickly
Brandon
Old 05-23-2007, 11:21 AM
Which port on the G5 do you have the Mbox 2 Mini connected to? Which drive are you using for recording and playback?
Support FAQ
Old 05-23-2007, 11:46 AM
I have tried back and front
i havent tried recording and am playing back from the internal hard drive
Old 05-24-2007, 06:00 AM
no one else has had this error before
Old 05-24-2007, 08:34 AM
First, using the internal drive is not recommended and could be the cause of the errors. You should try using a compatible external firewire drive or install a secondary internal drive.
Have you registered your Mbox 2 Mini and received the 7.3 amnesty update yet? If so, download and install that update and see if the problem still occurs.
You should also try a new administrator account and see if the problem occurs in the new account as well.
Support FAQ
CPU Usage error -6104 bortraws macOS 2 01-29-2012 11:09 PM
Error: (-6104) CPU usage holding off USB Audio twirk macOS 2 12-15-2011 07:14 PM
CPU Usage Holding off USB Audio -6104 error Mark Mangini 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-11-2010 07:05 AM
CPU usage error msg. -6104 Aleks B 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-22-2008 09:17 AM
CPU Usage is holding off USB Audio... error -6104 redrider307 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-27-2006 09:51 AM
