Play button flashes
Pro tools 12 windows 10.
I'm pressing the play button it gives a few flashes together with the stop button and nothing happens I searched the whole internet already for the last few weeks trying to get the right answer but nothing helps me is there anyone please please that can help me fix this problem I'm trying to record and play button flashes together with stop button and nothing happens Sent from my SM-G920P using Tapatalk |
Re: Play button flashes
Trash your preferences. Guitardom has made an app for Windows I think. I'm on a mac but here's a link to his thread on this. Or use Google and get instructions. I think that Sweetwater gives step by step to do it manually, too.
http://duc.avid.com/showthread.php?t=316863
Steve Shepherd Extreme Mixing |
Accidentally put it in extrrnal sync mode? (Easy to do...it's alt>spacebar. I only do it a dozen times a day.) Hit alt>spacebar again and see if it behaves.
And, make sure you didn't accidentally enable Wait for Midi Note
Possibility: open Playback engine dialog from Settings menu, change buffer to something other that your current selection, and (optional) then change it back.
Pro Tools HD Native 2023.12 | HD Omni | iMac Pro 10-Core 3.0 GHZ - 64 GB - 2 TB - Vega 56 | Ventura 13.5 | Sonnet Echo Express SE II for PT HD Native PCIe and UAD 2 Quad PCIe card | Avid Dock and S1 |
Play button flashes
I have this happen from time to time in Mac. It's related to the audio hardware. Shutdown. A restart will not work. After boot up make sure no other audio processes are running and the playback engine is set to what you expect. Any UAD cards by chance? Last edited by Matt Hepworth; 08-30-2016 at 08:06 AM. |
To the OP, welcome to the community :)
Steve S. |
I'm guessing it's "wait for note". Press F11 to toggle this function!
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
If no , what audio interface and driver are you using ?
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
Music won't play. Play button flashes and Stop button lights up | Mattitude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 24 | 04-16-2020 03:03 PM |
play flashes then stops. session wont play. | hellbert | Windows | 21 | 03-31-2011 10:49 PM |
Record 1 audio track, then go to record a second, the timer button flashes... help | tdubthatsme | General Discussion | 5 | 02-27-2011 04:39 PM |
Play button flashes before starting | jonathans9 | Pro Tools TDM Systems (Mac) | 5 | 04-19-2008 02:09 PM |
Dead Talkback on PC - button now flashes when held | audiomark | ProControl, Control|24, Command|8 | 2 | 12-14-2007 01:17 PM |
