Mbox2 mini - distorted sound in all programs
Hi all,
I am out of ideas here. I have a brand new PC running win 7 64 bit, and after installing LE 8.0.4, the sound output of the Mbox is horribly distorted in all applications, even windows sounds. It sounds like you have a distortion plugin turned on and a setting like "fried" selected. Even when you adjust the volume in windows and it makes the marimba sound, it sounds like you put some metallic reverb and distortion on it. I have been able to get 8.0.4 to work in win 7 64bit on my last PC, but this one just will not work. I have disabled onboard sound, and no other sound devices are active in playback devices. Please tell me someone knows how to fix this. It has to be a driver problem.. Thanks --Todd |
Re: Mbox2 mini - distorted sound in all programs
Sorry, I cant help you.
I have exactly the same problem on my mbox2 (not mini). My problem appears after about 5 minutes of use... only way to stop it is to quit pt, unplug mbox and plug it back in again. I have not been able to find much info on this problem. Have tried everything. Including changing usb ports (sometimes works apparently) The conclusion I am coming to is that my mbox is dying. |
Hissing/noise sound from mbox2 mini inputs | stump | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-12-2012 01:24 PM |
Do I need a sound card or will Mbox2 mini work?? | 1dbarks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-04-2010 08:49 AM |
Mbox2 Mini sound problem | aftershockottawa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-19-2008 01:24 PM |
Just purchased mbox2 mini getting no sound | roncarr53 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-21-2007 08:03 PM |
Can't set MBox2 Mini as WinXP default sound card | leeeeoooo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-28-2006 10:48 AM |
