MBOX 3 Problems
Hi everyone,
yesterday i got my new Mbox 3. Works fine so far. But the DSP Control Panel won't. It's just a bunch of pixels and graphical errors as you can see here: ScreenShot When i mouse-over the panel some buttons appear and some disappear. I tried the boxed and the newest Drivers from the avid homepage /// Mac Book Pro, 2,4 GHz, 4GB, OSX 10.6.6, Pro Tools 9 PLEASE HELP 1 I have another question about the mbox 3 hardware: when i conntect it via USB to my MacBook Pro not only the blue Power LED is lit but also DIM, Mono, Multi and +48 LEDs. When i press one of these buttons they just become more bright. PLEASE HELP 2 |
Re: MBOX 3 Problems
This is normal behavior and is configurable (no light when button not pressed).
regards wasserwerk |
Re: MBOX 3 Problems
Thanx a lot.
I couldn't have known that 'cause i can't use the Control-Panel. Do you know anything about that? I tried it on my iMac (also OSX 10.6.6) an it works fine. I even tried to switch graphic cards (onBoard to nVidia) --> same Problem. It sucks!!! |
Re: MBOX 3 Problems
Check this out:
http://codykrieger.com/gfxCardStatus/ There were some graphic anomalies on my 17" MacBook Pro, but after I started using this (with a fixed setting for the NVIDIA card) they all went away. The anomalies shouldn't of course be there in the first place, but... maybe fixed in 10.6.7? -matts |
Re: MBOX 3 Problems
Thanx a lot. But it still does not work.
Re: MBOX 3 Problems
Too bad to hear!
Is this the only software with this kind of anomalies? Did you use the 10.6.6 Combo updater? If not, you could re-install 10.6.6 on top of the current 10.6.6 using the Combo. Sadly there are differences depending on which way you update. I have no idea if this has anything to do with your problem or not, but since it is fairly easy to do, it might be worthwhile. -matts |
Re: MBOX 3 Problems
Thanx again,
i did not use the combo update, i'll this one. All other Application run great, cubase, logic, pro tools, open office whatever, it's just the Control-Panel. |
Re: MBOX 3 Problems
i tried the combo update. still not working. maybe i just sell the mbox again ...
Re: MBOX 3 Problems
And you're sure you have the latest driver (including the Control Panel) for your model Mbox?
Which Pro Tools version do you have: 9.0 - 9.0.1 - or 9.0.2? -matts |
Re: MBOX 3 Problems
Still not Working.
Mbox Driver 1.018 Pro Tools 9.02 OSX 10.6.6 (Combo-Update) The Mbox is working fine with Pro Tools and Cubase 6 it's just the Control Panel |
Mbox problems, please help | R Productionz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-05-2009 06:45 AM |
MBOX problems | chrinsua | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-07-2007 03:51 PM |
Mbox 1 problems | Purpleb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-07-2007 03:41 PM |
Problems with Mbox | nihil | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-03-2003 02:12 AM |
mBox USB PROBLEMS. PLEASE HELP. | iamvangelis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-19-2003 07:21 AM |
