How to turn an "S" to a "Z" wtih editing
I've just mixed a song and the singer has just realised that she did a mistake pronouncing a word. There's an "S" which should be a "Z" I'd like to know if someone ever faced sth like this and solved it in Protools (without re-recording o.c, just editing/plugins) P.S. there's no other Zs in other parts of song.
HD3 + Control 24 + 2 192s Mac Pro 12 core 2.93 & PT 8 16 Gig RAM Glyph Firewires Motu MTP AV USB |
Re: How to turn an "S" to a "Z" wtih editing
look for a word that starts with a sharp "t" and glue the very first part where the start of the "s" is. You may have to shorten the s as well. Maybe you want to pitch the s a little up or sharpen it a little with the EQ. You might bring it a little up in level as well. I would arrange the t, s, and the rest of the word on 3 tracks, so you can change the 3 parts faster .
hope this helps daniel www.ideeundklang.com |
Funny. Usually with us lazy Longk Oilanders it is the other way around!
Adding the T to the S as previously mentioned will work in Deutschland, where Z is pronounced "ts" as in "Zeit". Take that advice, and add a snippet of a sung note, pitched and with a soft attack, and this will give you a "hum" in the back of the "ts" and you should have a Z. You may need to tweak the T out, because an english Z is really a S with a hum. Huked on phoniks werkd four mee! Mike |
Thanks for the answers. I solved the issue by stealing a "Z" from another song of the singer and duplicating.
btw I'm also going to try the tips mentioned above, they sound pretty interesting.
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
PT9 Session Troubles - "Bus Error" in "Main Thread" & Could not complete the Open... | tohmit | macOS | 5 | 03-23-2011 12:13 PM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
The "FATE" of CM LABS "MotorMix" & "MotorMate". Dum dum dum dum... | leon777 | Pro Tools TDM Systems (Mac) | 21 | 10-15-2002 12:00 AM |
What's the difference between "online" and "offline" editing ? | stuu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-21-2002 03:46 PM |
