Well technically not about MIDI but i have a problem
So I have installed Pro Tools and the the Mbox. Whenever I do an audio track with a mic cable from my guitar to the Mbox, Pro Tools recognizes and records the guitar fine, being able to play it back with no question. BUT when I plug in a keyboard using a TRS line on an instrument track, Pro Tools only recognizes the signal from the keyboard, but when I try to record what I'm playing it doesn't record. SOMEONE HELP
Re: Well technically not about MIDI but i have a problem
Guitar uses a 1/4 unbalanced TS cable, not a mic cable which is XLR.. You can not record audio (which a guitar creates) onto an instrument track. Audio gets recorded to audio tracks.. Are you recording a MIDI guitar by any chance? Again, for the AUDIO from a keyboard you would record to an AUDIO track. To record the MIDI from a keyboard, you record to either a MIDI or an INSTRUMENT track...
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
my guitar has a mic output.
and my guitar is on an audio track and the piano on an instrument track
OK, so you need to use and audio track for the keyboard if all you want to record is the audio. Instrument tracks record MIDI
so from my output on the keyboard i would do an audio track. i would plug the trs into mic or DI.. doesnt matter? and it should record fine?
And that's just weird.. Does it have active pickups or something?
The mbox handles DI and Line level signals through the 1/4" jack, if I'm not mistaken. You would want to set it for line level. I'm not familiar with the actual button you have to use on the mbox..
Its an acoustic Dean Performer guitar. It has a TRS output and an XLR output. I use the XLR because it gives better quality.
On my Mbox2 the DI input is 1/4 in only. I would try the mic input from that XLR out of your acoustic, and see what you get. For the Keyboard, try the DI.
Either way, both get recorded to Audio tracks for sure, unless you are going to record through an Aux track, and then to an Audio track, but let's get this going first...lol
MacBook Pro 15in, 2.3gHz,i7 PT 2021.x PT12.8.x |
'Intelligent Harmonizer', technically Feasible? | Vercingetorix | Eleven Rack | 19 | 07-04-2011 06:27 PM |
With PT9, Are 00x Interfaces Now Technically Worthless? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 11-06-2010 02:20 PM |
Midi problem - no INPUT DEVICE option in MIDI menu | tam103 | MIDI | 2 | 01-05-2007 08:01 AM |
OK,, it's midnight, technically Nov. 1st -- | Infa | Pro Tools TDM Systems (Mac) | 13 | 11-01-2004 04:05 PM |
Why (technically spaeking) choose AMD over Intel ? | hanzoid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 78 | 12-22-2003 12:02 AM |
