Possible workaround PT crashing on startup with 10.4.9
I finally figured out how to get PT up and running on my Mac Pro with 10.4.9. I believe I am having the same symptom others have described where PT crashes immediately after being launched with the following error:
<font class="small">Code:<hr /><pre> Thread 0 Crashed: 0 dyld 0x8fe12f94 stub_binding_helper_interface + 18 1 <<00000000>> 0x00000000 0 + 0 2 <<00000000>> 0x01a0e134 0 + 27320628 </pre><hr /> I have tried all the suggested workarounds such as the combo 10.4.9 updater, the PACE rebinding, rebinding from the command line, trashing prefs, etc. with no improvement. I will say that I'm a bit miffed that this appears to be an issue related to the PACE copy protection built into Pro Tools. This kind of protection always seems to hurt legitimate users. Of course I could be wrong about this but that error shows up in relation to PACE and to other audio products like Max . And then of course there is the fact that prebound executables are deprecated and unnecessary at this point. But I digress... In debugging this I found that if I fire up Terminal, and launch the application from there, it just works! I have no further problems when using the app. I just run: <font class="small">Code:<hr /><pre> /Applications/Digidesign/Pro\ Tools/Pro\ Tools\ LE.app/Contents/MacOS/Pro\ Tools\ LE </pre><hr /> Hope it helps someone else out there, I'd love to see a fix for this one. |
Re: Possible workaround PT crashing on startup with 10.4.9
Just an update -- I upgraded to 10.4.10 (yes I know that is frowned upon, but I do other things with this computer besides run PT). I found that my previous workaround stopped working, and launching from the Finder still doesn't work. I tried the combo updater and redoing prebinding again and that didn't help.
But now, if I open PT this way from the Terminal, it works. <font class="small">Code:<hr /><pre> open /Applications/Digidesign/Pro\ Tools/Pro\ Tools\ LE.app </pre><hr /> WTF? Did I mention that I'm a big fan of copy protection software? |
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Sorry, I'm not going to bite on that one...
Perhaps my workaround will help someone else, that's why I posted it. |
2nd one worked for me in 10.4.9. Thanks!
Pro Tools 11.1 and 10.3.8 crashing on startup. | spoljar | Getting Started | 1 | 01-17-2014 11:59 PM |
PT 9.0.5 Crashing on startup!! | eanderso22304 | macOS | 3 | 10-05-2011 11:31 PM |
LE 8.0.4 Crashing at Startup on Network Mac | mmcconl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 10-12-2010 05:03 AM |
LE 8.0 crashing on startup | jbeband | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-23-2008 11:00 AM |
PT LE Crashing on Startup | beggehorn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-18-2006 09:18 AM |
